Old 4/5/10, 11:08 AM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Inspecting Water heaters
Training course
Kenton Shepard, Paige Peters, and a master plumber
Two water heater tanks (cut open to see inside)
Only $10 (on sale)
Check it out - http://www.nachi.org/advancedcourses...ot-water-tanks
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/5/10, 5:28 PM
Brian E. Kelly's Avatar
Default Re: Inspecting Water heaters
Why?
Old 4/5/10, 7:26 PM
Originally Posted by bkelly2 View Post
Why?
Why?
The reasons to keep learning are numerous.
One reason - Before producing the "water heater tank" training, I was not quite sure how a FVIR system on a tank works. After taking this course, any inspector will know.
Question: What maintenance does a FVIR system on a gas-fired tank require?
by the way, if you're googling "FVIR" right now, you need training...
BEN GROMICKO
Old 4/5/10, 7:36 PM
Just seems like you are leading HI's further away from a SOP copliant Visual Inspection into uncharted waters to me is all. Carry on.
Old 4/5/10, 8:51 PM
SOP is a minimum. Absolute minimum.
Knowledge however should have no limits.
Learn, learn, learn...
BEN GROMICKO
Old 4/5/10, 8:52 PM
So, what are the maintenance recommendations that home inspectors could provide their clients in relation to FVIR tanks?
again... if you're Googling "FVIR tanks," that may indicate a need for training.
BEN GROMICKO
Old 4/6/10, 12:26 AM
I have learned that if you venture too far away from the SOP you are no longer doing Home Inspections......
Old 4/6/10, 12:41 AM
2.6. Plumbing
I. The inspector shall:
C. inspect the water heating equipment,
And that's the objective of the training course. The course teaches the best visual-only inspection techniques to inspect the water heating equipment as required by the SOP.
BEN GROMICKO
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 10:23 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
