Old 7/6/09, 9:44 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Inspector Challenge Game
inspector-challenge-game-chuck-evans-homecert.jpg*
What are the concerns/defects in this plumbing picture?
I can see at least 6 things.
Try the Inspector Challenge Game for Panels. Free. Online.
*Picture provided by Chuck Evans of HomeCert, http://www.homecert.com/
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Find an InterNACHI certified Iowa Home Inspector (and anywhere else in North America)
Old 7/7/09, 12:09 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Re: Inspector Challenge Game
Ben,
Here is a photo for your files. The mind of a DIY'er. They amaze me sometimes.
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 7/7/09, 5:32 AM
Ben,
At least the tpr is not draining up hill
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 7/7/09, 10:51 AM
Jeffrey R. Pope's Avatar
I see TPR's on extensions like that, all too often. I can't imagine how someone could actually think that's acceptable. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/7/09, 11:28 AM
Jeff,
It's all about people not knowing what they don't know
Bruce M. Graham III
352 871 8989
NACHI05091592
ICC 5268478
Old 7/7/09, 11:37 AM
Mr. Pope and Graham,
I believe that there are many INSPECTORS (not just home owners) who do not know why the physical location of the tpr valve is a problem. To many, it doesn't look right, but they don't actually know (understand) WHY.
Do you agree?
BEN GROMICKO
Old 7/7/09, 11:53 AM
agreed, knowledge is power, and it can keep the attorneys at bay as well
Bruce M. Graham III
352 871 8989
NACHI05091592
ICC 5268478
Old 7/7/09, 12:05 PM
Originally Posted by bgromicko View Post
Do you agree?
Completely. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/7/09, 12:06 PM
According to the InterNACHI Residential SOP:
2.6. Plumbing
I. The inspector shall:
C. inspect the water heating equipment, including venting,
connections, energy source supply system, and seismic bracing,
and verify the presence or absence of temperature-pressure relief
valves
and/or Watts 210 valves;
If you inspect according to SOP, this defect/hazard (the physical location of the TPR valve) would or would not be reported? Which do you think?
BEN GROMICKO
Old 7/7/09, 12:13 PM
Regrettably, it could be argued that the location does not have to be reported, but if I were testifying as the EW for the plaintiff, I would blow you out of the water
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/7/09, 12:21 PM
Agreed, Mr. Pope.
I'm all for knowing what the problem is and reporting it, even though the inspection and reporting of the problem goes beyond the SOP.
As you said, regrettably... I don't even think the location of the TPR would fall under the requirement of 1.3.
1.2. A Material Defect is a condition of a residential real property, or any portion of it, that would have a significant, adverse impact on the value of the real property, or that involves an unreasonable risk to people on the property. The fact that a structural element, system or subsystem is near, at or beyond the end of the normal useful life of such a structural element, system or subsystem is not by itself a material defect.
1.3. An Inspection Report shall describe and identify, in written format, the inspected systems, structures, and components of the dwelling, and shall identify material defects observed. Inspection reports may contain recommendations regarding conditions reported or recommendations for correction, monitoring or further evaluation by professionals, but this is not required.
BEN GROMICKO
Old 7/7/09, 12:32 PM
It could easily be catagorized to fall within 1.2;
A Material Defect is a condition that involves an unreasonable risk to people on the property
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/8/09, 2:02 PM
Anyone see the match? Maybe for a pilot light problem? Or maybe someone testing the draft?
Should inspectors use a match to test draft?
BEN GROMICKO
Old 7/11/09, 10:56 AM
Attachment 29910
Probably not, but what good would it do? How would a HI evaluate the result (i.e. how much is enough draft?).
Previous question - isn't it enough for a HI to know the that TPR valve installation is incorrect and to report it? Does he have to know why?
(just had to 'stir the pot' a bit)
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 7/11/09, 1:06 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Ben
I see a lot of responses but I did not see a post for the actual defects of your post.
1) Improperly installed hot water inlet piping.
2) TPR improperly installed where the sacrificial anode rod is supposed to be.
3) Dissimilar metals.
4) No visible cold water shut off.
The tank appears to be gas but what is with the unprotected Romex.
I can not see enough of the tank at what is behind to make any more remarks.
I would call it out as a amateur installation and recommend a qualified plumber to properly install.
Now in regards to the TPR valve. If it was installed on the top of the tank on the hot water pipe instead of the side of the tank would this be an issue???
Play the new online Inspector Challenge Game. Electrical. Free. For fun only. gromicko Electrical Inspections 9 7/3/09 2:03 AM
Nuggets are in the house! swaskewicz Miscellaneous Discussion for Inspectors 0 4/20/09 6:11 PM
Help. We want to do a big Super Bowl Door Prize game. What teams are in the playoffs? gromicko Miscellaneous Discussion for Inspectors 5 1/1/08 10:17 PM
Tonight's Daily Door Prize donated by InspectorBOOST.com. Read game rules first. gromicko Miscellaneous Discussion for Inspectors 28 10/26/07 7:43 AM
Real estate game ends at CondoFlip jburkeson1 Miscellaneous Discussion for Inspectors 0 2/12/07 10:34 PM
