I am interested in installing a water filtration system to my home.
I have public water. We drink a lot of bottled water and it is expensive and even though I recycle I would like to add a filtration system. I was thinking about the cooler water stand but that doesnt seem the way to go. My questions are would you install just to the cold water under the kitchen sink or the whole house by the water heater. What types would you install. I have heard of the Water Boss. I could probably do myself if I had directions. I have an unfinished basement and it would seen easier to install in the sub floor. Would the filter need a shut off for maintenace? Any info or suggestions is appreciated. Thanks |
Maybe you need both.
If you want drinking water, install a reverse osmosis system for your icemaker and a drinking water tap at the kitchen sink. If you want to condition all water except irrigation water install a water softener. If your water is quite hard the R.O. unit will last much longer if it is supplied with soft water. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
David,
I get all my drinking water from a local well, I can't stand the taste of municipal water. If I were in your situaton, I'd install a filter at my kitchen cold water supply only. Your hot side supply gets boiled anyways and this boiling of water will be suffice. |
I have a standard carbon filter w/separate tap at the sink for all our drinking water. Works great for chlorine and other contaminates typically found in municipal water. Undersink RO's work great too, a bit expensive, but worth it if you find yourself buying a lot of bottled water.
Sounds like Mr. Macy should have his water tested to see just what he has and how to treat it before he spends big bucks on water treatment. IMHO
Dave....check out the PUR 3 stage system...available in home centers...attaches right to the faucet with easily replaceable cartridges...turn to use turn to by-pass...the wife fills a pitcher and keeps it in the fridge ...their literature is quite impressive and You can be up and running in 15 minutes for less than 100.00....Me i drink the plain tap water....Lake Erie water tastes great....anyhow a good inexpensive way to get started imo....jim
Why test again? Get ahold of the cities tests. |
The testing is simple and free in many places that sell water softeners. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Please don't fall for any of those WATER TESTING SCAMS either.
That's not the free testing I was speaking of anyway. Just don't by the magnet systems that I see advertised again. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Good luck finding credible support for these things. they might do something but they don't remove the Calcium ions that cause the hardness in the first place. http://www.csicop.org/si/9801/powell.html http://www.chem1.com/CQ/magscams.html You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
| Article on Commercial and Residential Inspections and Assessment | mcyr | Commercial Inspections | 2 | 8/6/07 1:26 AM |
| TPR & Combusiton Air | thejnicki | Plumbing Inspections | 16 | 9/18/06 8:55 PM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
