OK, this is something that has stumped me,
I have a inline J R smith flood control http://www.jrsmith.com/products/cana.../d7150_can.pdf It is F***ked from having not been maintained in probably 20+ years , the top of the housing where the shaft protrudes from is unattached, the screw threads are rusted out so when it rains the pit backs up with sewer water What i need to know is : What can i do without breaking up concrete to update, repair, trick out, the thing? has anyone dealt with this before? how would u call it out on a report, and what would you suggest? Joseph Tribuzio 708 456 1423 Tribuzio Home Inspection Services Inc. Entitiy Lic# 451.000692 ELMWOOD PARK, ILLINOIS www.thishomeinspector.com www.thischicago.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
Remove the old and re thread.
You can always re thread Joe. Why would you need to break concrete? Got a real picture? |
"Never ever threaten anyone in Camoflage" Tim Wilson "Not everyone follows the same path" Governor Sanford, musings on the Appalachian Trail
its like a sump pit deep- ive had plumbers suggest removal of the unit which would necessitate breaking concrete. I THOUGH THE SAME THING, : Clean it out, re thread it with a tap or helicoil it.... BUT In this case,it is so rusted and there is 20 plus years of neglect and water working on it , i would be really surprised if someone were able to helicoil it I don't think there is enough material to do it- too much muck and sewage debris to see it clear. Joseph Tribuzio 708 456 1423 Tribuzio Home Inspection Services Inc. Entitiy Lic# 451.000692 ELMWOOD PARK, ILLINOIS www.thishomeinspector.com www.thischicago.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
i tried once to remove the thing- it seemed stuck and i didn't want to be left with a open sewer in my basement I did not force the threads because it is a huge brass threaded peice tnhat is upwards of 400 bucks to replace- so if it isnt broke now i was afraid to bust it. I wonder if i can remove the assembly an temporarily cap it? Joseph Tribuzio 708 456 1423 Tribuzio Home Inspection Services Inc. Entitiy Lic# 451.000692 ELMWOOD PARK, ILLINOIS www.thishomeinspector.com www.thischicago.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
Plumber time
Give me a call. |
Its the actual part that is made of brass that is costly- can get around that one, its just expensive. Joseph Tribuzio 708 456 1423 Tribuzio Home Inspection Services Inc. Entitiy Lic# 451.000692 ELMWOOD PARK, ILLINOIS www.thishomeinspector.com www.thischicago.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
My little B&G pump for the miniature boiler downstairs (my office) is humming like a man using a shaver. I turn it off when I need silence. Yes I put in some 3 in one. |
Now i've also heard that there is a special tool, kinda like a clutch hub puller, that is required to dismantle it.
Has anyone dismantled one before? Joseph Tribuzio 708 456 1423 Tribuzio Home Inspection Services Inc. Entitiy Lic# 451.000692 ELMWOOD PARK, ILLINOIS www.thishomeinspector.com www.thischicago.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
Stop goofing around Joe and find a plumber that is familiar with that valve.
If i had found this during an inspection, i would suggest a plumber evaluate. I was just hoping some one experienced the same problem and could share some info on this kind of flood control system. - how to update, what happens when the plumber comes over.. costs etc. Joseph Tribuzio 708 456 1423 Tribuzio Home Inspection Services Inc. Entitiy Lic# 451.000692 ELMWOOD PARK, ILLINOIS www.thishomeinspector.com www.thischicago.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
AH, after inviting a few plumbers to check it out and researching it , i have finally gotten the valve open!!! Here are some pics to show what happens when these are not maintained right on a regular schedule.
one is a view of the opening in which the valve slides down on guides and stops back flow. the other is of the actual gate itself - threaded off the bolt. Joseph Tribuzio 708 456 1423 Tribuzio Home Inspection Services Inc. Entitiy Lic# 451.000692 ELMWOOD PARK, ILLINOIS www.thishomeinspector.com www.thischicago.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
| Find an InterNACHI certified Texas Home Inspector (and anywhere else in North America) |
here is a pic of the guide rails-inside the valve body, look closely
and also a pic of the work space i have... Joseph Tribuzio 708 456 1423 Tribuzio Home Inspection Services Inc. Entitiy Lic# 451.000692 ELMWOOD PARK, ILLINOIS www.thishomeinspector.com www.thischicago.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
here is the top plate top view and bottom view - this should be bolted to valve housing. but there were no bolts and threads are rusted worn- it will definitely need a tap.
Joseph Tribuzio 708 456 1423 Tribuzio Home Inspection Services Inc. Entitiy Lic# 451.000692 ELMWOOD PARK, ILLINOIS www.thishomeinspector.com www.thischicago.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting Last edited by jtribuzio; 9/4/09 at 4:10 PM.. |
| Seisco TWH does not need a TPR valve? | jyost | Plumbing | 4 | 10/6/08 9:01 PM |
| AO Smith Recall | ldapkus | Plumbing | 2 | 4/3/08 8:01 PM |
| Plumbing problem at home. | mnahrgang | Plumbing | 25 | 7/10/07 6:32 PM |
| Water Heater Pressure Valve | wrosario | Plumbing | 3 | 7/7/06 8:27 PM |
