Old 11/7/11, 9:48 PM
Leon Slack Leon Slack is offline
Default What kind of outlet is this?
I found this on the floor of the kitchen. Is this a gas outlet or a water outlet? There is an electric range in room and a fridge on other wall of kitchen.
Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/7/11, 9:52 PM
LeRoy D. Holm's Avatar
LeRoy D. Holm LeRoy D. Holm is offline
Default Re: What kind of outlet is this?
Water
www.tristatehomeinspections.org
www.tristateenergyinspections.com
If you always do what you always did you will always get what you always got.
Old 11/7/11, 9:53 PM
Christopher Currins's Avatar
It should be a water outlet, but that doesn't mean it is.
Christopher Currins
Certified, Licensed
Old 11/7/11, 9:55 PM
Yeah, it looks like a homeowner-installed gas range connection.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 11/7/11, 9:58 PM
That's what I was thinking.
Wasn't it traceable from below Leon?
Christopher Currins
Certified, Licensed
Old 11/7/11, 10:12 PM
When there, I assumed it was water. Later, I wasn't so sure, since there is an electric range installed in remodeled kitchen, I began to wonder if it was a previous gas valve for a former gas stove. I should have traced it. Kind of new, my mistake. Thanks. I guess I should just report it as either gas or water in my report. Any other suggestions.
Leon
Old 11/7/11, 10:13 PM
That white thread tape says "gas" to me.
(303) 717-8940
Old 11/7/11, 10:14 PM
Leon
Don't operate it. State in the report that you don't know what it is, that operating suspicious valves lies beyond the scope of your inspection, and recommend identification by a qualified plumbing contractor.
Those homeowner installed things, there's always the chance that when you touch it, it'll blow off the valve and start spewing gas all over the kitchen.
(303) 717-8940
Old 11/8/11, 5:18 AM
Russel Ray's Avatar
Really? It says water to me. I've never seen white thread tape on a gas line. The type of valve handle and what looks like a copper pipe coming out of the floor also say water to me. The valve handle is the type that is standard on toilets around here.
Old 11/8/11, 6:59 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
That is true Russel but you don't know who did the work. You cannot second guess this one. I would go on the safe side and get it checked by GAS authority since gas has been supplied by copper lines with no more than yellow tape wrapped around every 4 feet.
THE RIGHT TRAK
CIAQP, IAC2
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/8/11, 7:10 AM
Jeffrey R. Jonas's Avatar
Says water to me, potentially for the refer/icemaker.
Old 11/8/11, 7:53 AM
Michael Larson's Avatar
Exatcly!
Michael Larson
Hudson, WI
Old 11/8/11, 8:09 AM
Originally Posted by mlarson View Post
Exatcly!
And btw... never assume what is, always was. I bet that refer was originally infront or to the side of that valve.
Calling the gas co. to investigate that will cause a whole lot of embarrassmant to you and your company. I wouldn't do it without some very extensive searching on my own first.
Just sayin'.
Old 11/8/11, 8:11 AM
Just sayin'.
I would crack the valve and see what comes out.
Michael Larson
Hudson, WI
Old 11/8/11, 8:39 AM
The only reason I didn't mention that, is those valves are crap as far as I'm concerned, and didn't want him to risk it breaking in the open position. Safety first!
GFCI protected outlet not working dokeefe Electrical Inspections 19 6/6/11 7:47 AM
Dishwasher outlet tleahy Electrical Inspections 10 2/12/10 5:58 PM
Washing Machine Outlet < 6' from Utility Sink tdomingues Electrical Inspections 16 1/28/10 5:01 PM
What kind of Outlet tester do you use? jwatts1 Electrical Inspections 23 11/13/06 11:45 PM
