1960 house. Main plumbing vent in the attic. From a distance it looks like cast iron, However it is joined with a coupling and on close examination the black is some sort of coating.Looking closely at the coupling, it looks like the pipe material itself is white.
I'm wondering if this is Transite. I've seen Transite pipe many times, but never with any coating like this. If it is, it appears to be pretty well encapsulated. Can anyone confirm whether this is Transite (ACM) or some other material? Thanks Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Chuck,
This is a strange looking material. I've seen cast iron, PVC and galvanized stacks, but never ran into that type of material. Did you attempt to scratch it with a tool? Is it solid or is it able to be etched into? A lot of transite piping that I've encountered is gray. If you say it's coated with a material, them maybe the homeowner had it encapsulated due to it being transite. Even if it is transite (asbestos) it doesn't have to be removed if it's not friable. Simply note it as "plumbing stack appears to be an asbestos looking material". |
orangeburg ?
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Looks like cast iron to me.
This may be a possibility. If you look closely at the joint, you can see that the pipe has been turned so that it fits the coupling. It also doesn't look like the coupling has been cemented in any way ( I get the impression that this would be typical with Orangeburg). Also, though it doesn't show well in the photos, the upper section is not quite square in the coupling, which also tends support the non-cemented joint theory.
I did recommend that my client have a hydrostatic test performed on the system. The plumbers were just starting as I wrapped up my walkthrough. I'll find out how the test went. I'll also find out if they identified the type of pipe. Thanks Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Yes from a distance. But it was definitely not metallic. Cast iron would have used a hub with an oakum/poured lead seal for the joint.
[IMG]file:///C:/Users/ETHI/AppData/Local/Temp/moz-screenshot.jpg[/IMG]
![]() Orangeburg pipe |
Here some more on orange burg
http://www.youtube.com/watch?v=Bu_lktP_O4Q |
Nice video. Imagine being the guy on the other end of that camera pulling it back in from the waste pipe. The smell alone would make me want to blow chunks. And then, how the hell do they sanitize that shi++y camera snake after use? |
When i got out of high school i worked for a company called underwater tel eye. Main job was running a camera threw sewers . it was different for sure . Best fun was when the camera got stuck and i had to crawl the pipe to get it back. good money though and all you could eat lolol
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 2:23 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 9:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 7:39 PM |
