Old 7/10/11, 5:22 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Kitchen Island Plumbing
Tell me what I am not seeing here? This is plumbing under the kitchen sink at island. Thanks
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/10/11, 5:42 PM
Michael Larson's Avatar
Default Re: Kitchen Island Plumbing
This may help
Michael Larson
Hudson, WI
Old 7/10/11, 8:08 PM
Banned
Originally Posted by mlarson View Post
This may help
That's a good way to vent that trap..........SIGH!!! It would be nice to see one like that. Did a $350,000 home with an island sink yesterday......didn't look like that under the sink!!
Old 7/10/11, 8:27 PM
Banned
Here's an even better one...diagram only:
http://www.longbeach.gov/civica/file...p?BlobID=17060
The cleanout at the vertical wall vent pipe allows for cleaning the horizontal vent run if it ever gets blocked due to a sewer backup, etc.
Old 7/10/11, 9:04 PM
Jeffrey R. Pope's Avatar
If your jurisdiction follows the UPC, then you have an improper installation there. Two traps are not allowed to share one trap arm under the UPC.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/11/11, 8:17 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Jephrey is correct. The arrangement is wrong and will need corrected.
Adding to this is it will most likely cause trouble because it is feeding from a garburator increasing the speed of discharge. This will create suction on the one trap which will no longer function as a trap.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 7/11/11, 12:23 PM
Kathleen Luuk's Avatar
Kathleen Luuk Kathleen Luuk is offline
Thats a really good image you posted Micheal, do you mind me asking where you obtained it? Plumbing is my weak spot and I would like to see more images such as these. They are so much more informative than drawings.
Old 7/11/11, 12:24 PM
http://hostedmedia.reimanpub.com/TFH...ISLANSI_01.JPG
Michael Larson
Hudson, WI
Old 7/11/11, 12:58 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
On the back side of that double wye, what's connected? Is it just capped?
I rarely see the set-up like in Mikes photo. These days all I see is AAV's.
Old 7/12/11, 3:02 PM
Robert J. OConnor's Avatar
Not if your on IRC based codes like most of the country. Also I see both on the same trap arm all the time, and this question/topic has come up before.
According to plumbers I have asked, having a garbulator and sink on the same trap arm is no more problematic than having each one with it's own trap arm connected to the same line, as long as it is done correctly. And the garbulator drain connections are sized to not completely fill the trap arm and branch pipe ...
The only issue I have is that any garbage disposal unit can have a negitive impact on any on-site septic disposal system.
JMO & 2-Nickels ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 7/12/11, 3:22 PM
KEVIN WOOD's Avatar
Both on the same trap is correct.
We are dealing with the designed one in the picture that is wrong.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 7/12/11, 4:34 PM
Yes, I meant trap arm ... fixed ... .
The IRC permits both to be connected to one trap arm ... http://publicecodes.citation.com/ico..._31_sec007.htm
Robert O'Connor, PE
The Importance of Bathroom and Kitchen Fans mkyriacou Interior Inspections 35 6/4/10 5:27 PM
What do u consider kitchen? rwashington Inspecting HVAC Systems 10 6/6/09 6:26 PM
Kitchen floor slopes?? crichiii Structural Inspections 6 5/29/07 7:24 PM
No GFCI in Kitchen rnewland Electrical Inspections 6 9/19/06 7:51 AM
