Old 12/24/11, 12:04 PM
Jeffrey M. Cohen Jeffrey M. Cohen is offline
Default kitchen sink trap
I came across this kitchen sink today in a 3 family apt house. It does not seem to have any trap. The drain goes down through the floor rather than into the wall. Should a P trap be the requirement.
Thanks
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/24/11, 12:45 PM
Default Re: kitchen sink trap
It is not uncommon to see the trap below the floor. As long as the trap arm does not exceed 24".
Old 12/24/11, 2:31 PM
Bob Elliott's Avatar
If that is not the basement directly below or no trap was visible call it out.
Should be right there anyhow and gosh that looks ugly.
Old 12/24/11, 2:34 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Call this one an easy fix.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/24/11, 2:39 PM
Christopher Currins's Avatar
Installing a vented P-Trap would not be that easy of fix.
Christopher Currins
Certified, Licensed
Old 12/24/11, 4:22 PM
An HI An HI is offline
Please Note: An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
Agree
Old 12/24/11, 5:33 PM
KEVIN WOOD's Avatar
Looks like we have some plumbers on the MB!
It is probably vented in the wall if not an AAV would not be hard to install.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/25/11, 12:08 PM
This was on the 2nd floor and I wants able to see anything below the floor so it will definitely be called out. All the other sinks had proper traps. It may be below the floor but I will never know. Thanks all....
Old 12/25/11, 12:53 PM
KEVIN WOOD's Avatar
Jeffrey C
Here is one from a third floor apartment.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/4/12, 9:51 AM
Amalia Markous Amalia Markous is offline
Please Note: Amalia Markous is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hello friends,
My home was constructed about ten years ago, and no trap was installed under kitchen sink. Drain drops directly into floor. Counter top holding the sink rests against a half-wall, so It's obviously not vented. Just wondering if there's any connection between venting and use of a p trap. Should I install one?
Thanks a lot.
Amalia Markous
________________________
Plumbing Services Fort Worth
Old 1/4/12, 11:14 AM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Originally Posted by Amalia Markous View Post
Hello friends,
Thanks a lot.
Amalia Markous
I would recommend you contacting a plumber to do the requested repair.
A ARV valve could be installed.
You could take some pics and post them and many can help you through it.
Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas.
Old 1/4/12, 2:13 PM
Jeffrey R. Jonas's Avatar
David...
This is SPAM.
Look at the link in their post... it's a Plumbing Service !!!
Old 1/4/12, 2:32 PM
Originally Posted by jjonas View Post
David...
This is SPAM.
I see said the blind man
Old 1/30/12, 2:03 AM
moe larry curly moe larry curly is offline
Please Note: moe larry curly is a non-member guest and is in no way affiliated with InterNACHI or its members.
David...
This is SPAM.
Its not spam its someone making fun of you ( I took a two week course and think I know how to inspect plumbing guys)
Condensation Drain line question acassady Inspecting HVAC Systems 25 2/26/12 11:40 AM
S-Trap? Part2 wmisegades Plumbing Inspections 9 12/12/11 8:07 PM
Composite granite kitchen sink ... good choice? Bill Featherstone Plumbing Inspections 6 1/8/08 11:03 PM
