Go Back   InterNACHI Message Board > Specific Inspection Topics > Plumbing
Plumbing Contains discussions about plumbing.
Old 7/30/09, 1:14 PM
John Evans John Evans is offline
Default Laundry Drain
The washing machine drain is connected directly to the main drain pipe without a stand pipe or trap. Calling this out as improper connection. The sump pump (discharging the laundry sink water), is connected the same way. Reporting this connection as improper, the sink should discharge by an enclosed pump, not an open sump well. Opinion on the condensate drain, will the trap hold enough water to maintain a seal?
Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 7/30/09, 6:34 PM
Default Re: Laundry Drain
Attachment 30439
Attachment 30440
Attachment 30441
Attachment 30442
No the condensate drain will dry out when the HVAC sytem is off.
"Never ever threaten anyone in Camoflage"
Tim Wilson
Laundry drain? mmerino Plumbing 8 5/21/09 12:21 AM
Inspector in hot water after approving unit without drain rcooke Canadian Inspectors 6 2/20/08 3:59 PM
Ill inspector 2nd floor laundry floor drain? ebethel Plumbing 1 7/18/07 9:59 PM
drain for laundry brepanshek Plumbing 1 6/3/07 7:51 PM
French drain tied into main drain rwashington Plumbing 6 2/16/07 11:04 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
