I found this today. This is some type of lift or grinder pump, it discharges into the sump pump. The sump pump discharges underground, termination point is unknown, I think I know where, but not sure.
What do you GUYS, say??? Thanks, for the help Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified Maryland Home Inspector (and anywhere else in North America) |
Was hooked in to a toilet ? |
Thanks! No, it discharges directly into the sump pump.
This is an above ground sewer ejector (that is seeping at all penetrations). The only place this ejector should be discharging to is to a main waste line, not a sump pump.
![]() That's nasty. |
Thanks! David. I deferred it to a plumber.
This is another excellent reason not discharge the washer directly to the sump pump. The entire basement was flooded.
'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com Last edited by mkyriacou; 10/17/09 at 2:01 AM.. |
More pic's
More info at: http://libertypump.com/Products/Cate...?p=19&s=0&c=23 Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
| Laundry Drain | jevans | Plumbing Inspections | 1 | 7/30/09 7:34 PM |
| Laundry drain? | mmerino | Plumbing Inspections | 8 | 5/21/09 1:21 AM |
| Ill inspector 2nd floor laundry floor drain? | ebethel | Plumbing Inspections | 1 | 7/18/07 10:59 PM |
| drain for laundry | brepanshek | Plumbing Inspections | 1 | 6/3/07 8:51 PM |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/17/07 12:04 AM |
