Old 7/15/11, 2:05 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Lifted sewer cap and see water pooling....
2005 Built residence on slab....
Everything checked out good....opened
the steel cap labled (Sewer) in the garage. I seen the
ABS pipe capped.....but the surrounding are
was full of water.....Is this a sign of a problem?
David
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/15/11, 10:23 AM
Banned
Default Re: Lifted sewer cap and see water pooling....
Was there sewage odour from the water? Or no discernible odour?
No discernible odour........where was the water service line....buried along side the serwer line? could there be a leak from it?
If no odour/leakage, the water table would appear to be extremely high. What about grading around the place....flat, inward sloping, the house on a pad raised from the surrounding land?
I have seen a spring appear under a slab about 6-7 months after it was was poured during a very dry summer. When the fall rains came, the water tables raised and came up through cracks/penetrations of the slab.
Old 7/17/11, 9:38 AM
Robert J. OConnor's Avatar
The cover says sewer, but what is that in the pit? Cleanout plug ... or maybe something else? Hard to see.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
