Old 8/5/07, 1:01 AM
Christopher Currins's Avatar
Default Like This TPR Valve
Compression fittings and all.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 8/5/07, 9:01 PM
dchew dchew is offline
Default Re: Like This TPR Valve
You could write up the TPR piping since it's suppose to have no kinks or restrictions in the piping.
Are you sure that this is the TPR plumbing? I see a pipe going up from water heater. Looks more like a pressure relief valve to me. Is there a Watts 210 on the gas line?
Old 8/5/07, 11:33 PM
homebild homebild is offline
Hard to tell from the photos, but it doesn't look at all like a TPR to me.
Looks like some kind of branch off of one of the water supplies....?
Probably the remnants of piping that once connected to an expansion tank...
Nothing wrong per se with compression fittings, but the ones this installer used were for gas and he used them on water.....
Old 8/6/07, 1:36 AM
That's what it is, right off of the cold water supply. Gas fittings, that's why I showed both pics. I barely touched it and it slid right off. It is a Richmond 1992. Someone had put a galvanized plug where the valve is to connect to on top. If water did shoot out it would hit the furnace, which is about two feet directly behind it.
Christopher Currins
Certified, Licensed
Mixing valve question cmettel Plumbing Inspections 2 6/17/07 11:03 PM
Backwater valve in new homes? ccrooker Canadian Inspectors 16 11/28/06 8:47 AM
Water Heater Pressure Valve wrosario Plumbing Inspections 3 7/7/06 8:27 PM
Pool inspections/ valve check dbucknavich Ancillary Inspection Services & Additional Topics 1 6/21/06 4:33 PM
Manifold connections, mixing valve question jclark1 Plumbing Inspections 14 6/15/06 11:46 PM
