Old 7/22/08, 3:35 PM
Andrew Cox Andrew Cox is offline
Default A little help
How would you comment on this water heater? It's 8 years old. The TPR eventually vents out to the exterior of the house. I know it can't be inline with the other device. How would you word it?
Thanks.
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 7/22/08, 3:46 PM
Michael Larson's Avatar
Default Re: A little help
The device on top is THIS
It is used to prevent excessive pressure in the supply lines.
May or may not be allowed by local code. Check with your AHJ.
Michael Larson
Hudson, WI
[/I]
Old 7/22/08, 4:23 PM
Yeah - it's a relief valve, but I've understood the 2 can't be inline, they have to discharge separately. Right?
I'm looking more about the TPR extension, it runs back up and around the tank.
Andy Cox
Kissimmee, FL
Old 7/22/08, 4:25 PM
TPR should discharge where it can be seen by the occupants, preferably in the same room.
The pressure relief discharging through the tee into the TPR drain line, may or may not be permitted by the local code inspector.
Michael Larson
Hudson, WI
[/I]
Old 7/22/08, 9:24 PM
Richard D. Slocum's Avatar
Richard D. Slocum Richard D. Slocum is offline
The TPR valve should NEVER run up ! If sediment gets into the line and basically creates a plug, the consequenses can be catastrofic.
Rick Slocum
NACHI # 04072697
Elizabeth CO 80107
ABSOLUTE Home Inspection Service
Old 7/25/08, 1:12 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Needs attention by a licensed professional. Not supposed to tie the 2 together. Your right serperate lines.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 7/25/08, 1:23 PM
These devices and installation type have been discussed several times here.
Check with your local AHJ.
Michael Larson
Hudson, WI
[/I]
Old 7/25/08, 5:29 PM
Jonathan T. Hittle's Avatar
Jonathan T. Hittle Jonathan T. Hittle is offline
As for Ohio this is a very big no no!! The previous inspector was correct the line should not run up. This is very dangerous. Also it should terminate where you can see it. There is no need for this other relief valve. If the TPRV is working properly it will notify you when there is too much pressure. Also this installation is hideous. Nothing about the way this is put in should have been done that way. I am also a licensed plumber and pipefitter and if I did anything like this I would loose my job and all credibility with the code inspectors. As I said this is a no no in Ohio. Hope this helps
