Old 8/20/06, 9:06 AM
DSuelflow DSuelflow is offline
Please Note: DSuelflow is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default A little help please
Hey, I need a little help identifying my plumbing fixture. I need to rebuild it and don’t know what brand it is. The home was built in the late 50’s. Thanks in advance.
little-help-please-hall_bath-001.jpg   little-help-please-hall_bath-002.jpg   little-help-please-hall_bath-003.jpg
Old 8/20/06, 9:22 AM
Roy D. Cooke, Sr's Avatar
Default Re: A little help please
I expect if you where to take these taps apart ( Shut The water of first ) and go into a good plumbing supply shop they will be able to supply all new parts to upgrade the system .
Print of a couple of sets of pictures full size for them to see.
This should get you pointed in the right direction .
Good Luck PS use lots of penetrating oil
Roy Cooke .. Royshomeinspection.com
Old 8/20/06, 10:29 AM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
On my house I found that it was far less expensive to replace the fixtures with new rather than replace the valve stems, seats & screws. The valve stems alone, when I was able to find the correct ones, were around $40.00 each. I could get a new fixture for well under $120.00 at Home Depot or Lowe's.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 8/20/06, 12:42 PM
Yes you are correct but did you not have to do some tile work after the new taps .
If the tile is fine then why destroy it .
Roy Cooke
Old 8/21/06, 12:21 PM
Roy Cooke
No, I did not have to do anything inside the bathtub area at all. Most bath/shower mixers are a standard hole spacing. All the work I needed to do was done from the access panel in the closet behind the shower wall. I only had to cut the four copper lines, clean them up and sweat on the new mixer with some extensions added. It took me all of about an hour. I also noticed that there were no shut-off valves to my bathtub so I had to turn off the water at the main.
I have done a lot of these when I did handyman work. I have rarely had to do any tile work in the tub or shower unless I was changing the mixer to a different configuration. eg.: 3 handle to a single handle, etc.
Jason Sieg, CMI
Davison, MI
NACHI05091399
ssieg@gfn.org
