Old 9/26/11, 1:43 PM
Jonathan M. Cartwright Jonathan M. Cartwright is offline
Default Lots of water heating
Good morning,
I inspected a large home - 7058 sqft. Two large gas fired water heaters with a small circulating pump. The heaters are plumbed one after the other in series.
My question is why are there two much smaller storage tanks located after these heaters?
Is this storage to prevent running out of hot water during peak usage? - 7 bathrooms.
Signed,
Not clear in the basement utility room
Newberry Inspections, LLC
www.newberryinspections.com
775-323-1117 phone
775-323-8117 fax
775-287-1932 cell
Serving Reno/Sparks, Carson City, Fernley and all surrounding areas.
Home, Termite/Pest, Fireplace/Chimney, and HVAC Inspections.
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/26/11, 3:34 PM
Default Re: Lots of water heating
All appear to be functional hot water heaters to me.
Perhaps they have friends over who use a lot of hot water............
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 9/26/11, 3:45 PM
Wayne B. Wilson's Avatar
Just for storage no power to the little ones , they didn't happen to heat the place with hot water did they?
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 9/26/11, 4:14 PM
Christopher Currins's Avatar
The smaller two have No power source.......hot water storage tanks.
All do equal a functional water heating system.
Christopher Currins
Certified, Licensed
Old 9/27/11, 9:56 AM
No power to the smaller units. Just acting as storage tanks. But why?
Unless there is a relatively constant usage where these tanks are replenished with hot water wouldn't this just allow the smaller tanks to cool?
Heating is all gas forced air.
775-323-1117 phone
775-323-8117 fax
775-287-1932 cell
Old 9/27/11, 11:39 AM
Robert Ernst Robert Ernst is offline
Where does the pipe in the right side of the picture with the two heaters go to? What about a snow melt system. With a house that big it's a possibility?
Nevada Inspector of Structures #1730
Nevada Energy Auditor #30
www.homecsi.com
Old 9/27/11, 1:27 PM
Copper pipe at the right of the large heaters is connected to the circulating pump located near the floor.
775-323-1117 phone
775-323-8117 fax
775-287-1932 cell
Old 9/27/11, 2:15 PM
James H. Bushart's Avatar
That would be my guess, but I don't understand why the two powered units are insulated and the two holding tanks are not. What is the total holding capacity when you add all 4?
Looks to me like a good argument for "on demand" water heating equipment.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 9/27/11, 2:27 PM
The tanks are connected in series, it's like one big tank. Cold water enters system at right tank, is heated, fed to small tank at far left, then to next small tank, then to large tank at left, heated again if necessary, then fed to house distribution system.
Christopher Currins
Certified, Licensed
Old 10/2/11, 11:19 PM
Not true if you follow the pipes. The photos do not make this clear but all of these heaters/tanks are connected in series with the two heated tanks first and then the two unheated tanks last. Makes no sense to me but I thought there may be a reason.
Thanks to all for your comments.
775-323-1117 phone
775-323-8117 fax
775-287-1932 cell
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 9:18 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
