Old 2/14/11, 11:59 PM
Joe Funderburk, CMI's Avatar
Question How many call this out as a significant issue?
Anybody see a concern?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/15/11, 12:01 AM
rsmith24 rsmith24 is offline
Default Re: How many call this out as a significant issue?
No cement, No clean out
INSPECTIONLOGOS.COM
"I can keep explaining it for you, but I can't understand it for you".
Nick G.
Monroe Home Inspection
Old 2/15/11, 12:05 AM
There is cement. This particular photo is not a clean-out issue. You are very close, however.
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/15/11, 12:09 AM
Stephen W. Stanczyk's Avatar
I hope the guy drops a wedding ring down the sink. Should have fun tearing it all out and starting over.
Stephen Stanczyk
Old 2/15/11, 12:17 AM
2009 IRC P3003.14.2 Solvent cementing. Joint surfaces shall be clean
and free from moisture. A purple primer that conforms to
ASTM F 656 shall be applied
. Solvent cement not purple in
color and conforming to ASTM D 2564, CSA B137.3 or CSA
B181.2 shall be applied to all joint surfaces. The joint shall be
made while the cement is wet, and shall be in accordance with
ASTMD2855. Solvent-cement joints shall be permitted above
or below ground.
Code Commentary: PVC plastic pipe requires a primer
prior to solvent cementing. Although ASTM F 656 only recommends that
PVC primer be purple, this is a code requirement. The
purple coloring is intended to allow the installer and the
inspector to verify that the required primer has been
applied. To distinguish the difference between primer
and solvent cement, the solvent cement must be a
color other than purple. Solvent cement for PVC is typically
clear. First, primer is applied to both the fitting
socket and the pipe. The PVC solvent cement is then
applied to the pipe and socket fitting. The joint is made
with a slight twisting until the pipe reaches the full
depth of the socket fitting. It is then held in place until
the solvent cement begins to set. The installer in these
figures is wearing impervious gloves to prevent solvent
cement from coming into contact with the skin.
The solvent-cementing procedure must be done in accordance
with the referenced standard.
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/15/11, 12:23 AM
Thats why I didn't think there was cement, to clean but I guess they just didn't use primer.
INSPECTIONLOGOS.COM
Nick G.
Old 2/15/11, 12:25 AM
The entire house was like that. I see it a lot.
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/15/11, 12:36 AM
They used Oatey clear primer. Good for PVC and CPVC so there is no need to carry more than one type. Look at the lettering on the pipe. It is smeared like someone used a primer.
http://oatey.com/Plumber/Shared/Prod...ar+Primer.html
Stephen Stanczyk
Old 2/15/11, 12:38 AM
Stephen, please re-read the code.
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/15/11, 12:41 AM
(19) Amend sections P2905.9.13 of the International Residential Code 2009 by replacing said
section with the following language:
Section P2905.9.1.3 PVC Plastic pipe. A primer that conforms to ASTM F 656 shall be applied
to PVC solvent cemented joints. Solvent cement for PVC plastic pipe conforming to ASTM D
2564 shall be applied to all joint surfaces.
(20) Amend sections P3003.9.2, and P3003.14.2 of the International Residential Code 2009 by
replacing said sections with the following language:
Solvent cementing. Joint surfaces shall be clean and free from moisture. A primer that conforms
to ASTM F 656 shall be applied. Solvent cement not purple in color and conforming to ASTM D
2564 or CSA CAN/CSA-B137.3, CSA CAN/CSA-B181.2 or CSA CAN/CSA-B182 shall be
The joint shall be made while the cement is wet and shall be in
accordance with ASTM 2855. Solvent-cement joints shall be permitted above or below ground.
INSPECTIONLOGOS.COM
Nick G.
Old 2/15/11, 12:46 AM
Not sure what you are getting at Robert. The primer is supposed to be purple and the cement is supposed to be not-purple.
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/15/11, 12:51 AM
Oh I highlighted the wrong section but it seems they amended the part that read the primer has to be purple.
INSPECTIONLOGOS.COM
Nick G.
Old 2/15/11, 12:56 AM
Perhaps your state did. I posted the International Residential Code, 2009, above.
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/15/11, 6:42 AM
John Harrison's Avatar
John Harrison John Harrison is offline
We are not code inspectors. I would inform the client that there is no cleanout, or way to take the fitings apart without cutting it out.
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Active Rain Member
Old 2/15/11, 6:50 AM
Eric C. Van De Ven's Avatar
Eric C. Van De Ven Eric C. Van De Ven is offline
Maybe the installer was very careful when applying the primer. Or, like I do, maybe he taped off the rest of the pipe so it has a neat appearance when finished.
Personally, I don't like the purple primer. It is not the easiest thing to get off your hands!
Or, he used this:
Primer
Tankless water heater issue sstanczyk Plumbing Inspections 18 12/2/10 6:15 PM
Cell Phone Do not call #'s bjones5 Canadian Inspectors 10 1/31/09 12:17 PM
Call for Volunteer - 1 week in Guatemala Rob Robinson General Inspection Discussion 0 10/15/08 4:03 PM
Cutler-Hammer CH breaker issue Marc D. Shunk Electrical Inspections 4 5/27/07 2:04 PM
