Old 12/1/11, 11:55 PM
David Hays David Hays is offline
Default How many p-traps LOL
How many p-traps can you put under a sink. There are 3 between the disposal and the stack LOL. Just another Fix and Flip.
many-p-traps-lol-pb300615.jpg many-p-traps-lol-pb300616.jpg many-p-traps-lol-pb300620.jpg
No insulation for dishwasher, not attached and the water line is kinked.
David Hays
All Points Home Inspections LLC
Denver, CO
720-670-0366
allpointshomeinspect@yahoo.com
www.allpointshomeinspections.org
Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/2/11, 12:45 AM
Gary D. Rowden Gary D. Rowden is offline
Default Re: How many p-traps LOL
I guess they won’t have to worry about gases backing up in the disposal, the downside; it won’t take long for the drain to start clogging up.
Also the air gap is missing
Old 12/2/11, 1:02 AM
Tim Spargo's Avatar
Looks like along with the *extra* traps... did they install an AAV where the D/W would normally dish-charge?
Loop the dishwashing machine drain line as high as possible in the sink cabinet and securely fasten or install an air gap device
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 12/2/11, 1:59 AM
You guys saw the same things I saw. There was also no clamp at the disposal cable, flexible drain lines in the bathroom sinks, leaking bathroom sink supply and drain lines etc...
These fix and flip contractors take so many short cuts. They must not think that the buyers will have an inspection.
David Hays
Denver, CO
720-670-0366
Old 12/3/11, 11:44 AM
Scott May's Avatar
Scott May Scott May is offline
Send a message via Skype™ to smay
The words realtors try to sell are... brand new.... toatally renovated ... lets not forget turnkey, no need for an inspection. As soon as I see "new" reno work the spidey senses go into hyper drive.
The best advice i give a client is ask to see the permits. JMO
Try not to become a man of success but rather to become a man of value!
WWW.eyespy-homeinspections.ca
Serving: Collingwood, Creemore, Dundalk, Durham, Flesherton, Hanover, Kincardine, Mansfield, Markdale, Meaford, Owen Sound, Port Elgin, Sauble Beach, Shelburne, Southampton, Stayner, Thornbury, Wasaga Beach and Wiarton.
Old 12/3/11, 12:32 PM
Jeffrey R. Jonas's Avatar
At least you are in an area that requires permits. Many areas around me do not, or only for specific work, like installing or replacing a septic system.
Old 12/5/11, 7:06 AM
Scott May's Avatar
That is scary Jeff! I just had an incident where a neighbours builder was trying to install a septic right on the property line. Here they are supposed to be 3 meters (10ft) but are usually given some leeway to 5 ft...but not zero. My leech field is close to the property line as well, plus they have raised their lot level significantly. One call to building inspector and it was moved .. along with the property rain runoff it would have saturated my property. I am in a rural araea so you have to watch out for yourself as builders will try to get away with anything to save a buck!
I have to wait for final grade to make sure that they install a swale for the run off...I already advised the builder that I would be checking.
Thank God for compliant permits.
Triple Traps kblair1 Plumbing Inspections 7 4/16/10 8:08 PM
two inline traps at sink??? jwickline Plumbing Inspections 12 4/7/09 5:15 PM
Bottle Traps krichardson Plumbing Inspections 11 8/28/08 9:47 PM
Illegal traps dmacy Plumbing Inspections 1 5/22/07 10:19 PM
