Old 1/27/07, 4:56 PM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default max drain pipe length
are these drain pipes longer than allowed?
if so, any official requirement to back it up?
Old 1/27/07, 5:19 PM
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
Default Re: max drain pipe length
Now thats one nasty little set-up. Firstly, I believe it should only have one p-trap per fixture and I think they class a double sink as one fixture. Secondly, I think that set-up could result in drainage/venting problems. I'm sure you'd be safe to say to have a plumber evaluate and correct. : Also was it vented??
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 1/28/07, 4:46 AM
David P. Valley's Avatar
UPC says this is a no-no, but the IRC allows it.
Under the IRC you may connect two traps to one waste arm however the diameter of that waste arm must be sufficient to handle the combined Drainage Fixture Unit (DFU) load of the two trapped fixtures.
The UPC prohibits two traps connected to a common waste arm. Under the UPC when two back to back sinks are connected to a common vertical riser they must be connect by means of a Sanitary cross (Double sanitary Tee) with a separate waste arm to each fixture.
Old 1/28/07, 10:17 AM
How about for the length of the drain pipes coming off of the sink?
Old 1/28/07, 11:22 AM
Jeffrey R. Pope's Avatar
24" is the maximum allowable length for the tail piece - except for a washing-machine standpipe, which can be 36".
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/28/07, 12:06 PM
thanks jeff.
i see you posted this in brian v's tub question.
thanks
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
drain pipe nbhi Plumbing Inspections 6 4/5/06 10:51 PM
Proper distance between a washer drain pipe and 220 volt dryer connection rpaul Electrical Inspections 14 1/3/06 9:43 PM
