The pressure to this system was a bit excessive. I guess that's why shutoffs were installed on the pressure-relief valves. . .
| Find an InterNACHI certified Nebraska Home Inspector (and anywhere else in North America) |
Wow... never seen it peg before. Was that on city or private well?
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Well yea... The TPR is designed to open at 150psi. Only time I've ever seen it go that high is when my pressure valve broke.
City supply. It's actually pretty common in these parts. . .
It looks like that one shutoff was even leaking!
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
Is a shutoff valve on the TPR smart? If the valve malfunctions and blocks the pressure from releasing isn't that WH going to be flying to the moon...
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
No, it is dangerous.
Or beyond... InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Pressure relief vales must never include a shutoff or other system that may inhibit their function. In the case of the plumbing-system relief valve, the worst case might be a pipe burst, however, with regard to the water heater, this setup could result in catastrophic property damage, and possibly loss of life. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Jeff Garner is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mythbusters did a show on water heaters, building a mockup house then plugging the TRP on a water heater...
http://www.youtube.com/watch?v=JmJoyuUJj2Q |
| Water Pressure..... | David Smfh | Plumbing Inspections | 7 | 5/4/08 1:49 PM |
| Reverse Osmosis | phinsperger | Plumbing Inspections | 3 | 10/30/07 6:28 PM |
| Hydrostatic Pressure Test | Edward D. Wend | Plumbing Inspections | 9 | 6/5/07 3:58 PM |
| air pressure test vs. hydrostatic pressure | mcyr | Plumbing Inspections | 22 | 7/11/06 6:11 PM |
