The minimum slope for a pvc plumbing drain line is 1/4" per foot (some jurisdictions wil allow 1/8th"). What is the maximum slope allowed?
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
You can go straight up. Can you explain the question.
I remember there was an ideal slope. Anything other than that was bad. Too low, nothing drains. Too much, the liquid leaves behind the solids.
tom |
Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Slope. The horizontal combination waste and vent pipe shall have a maximum slope of one-half unit vertical in 12 units horizontal (4-percent slope). |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
The "no" zone is anything between: 1/2" per foot and a 45 degree angle. 45 degrees to vertical is considered vertical and is okeedoekee.
I also know the max to be 1/2" per foot (until you get to 45 degree or more) but I don't have a referance
| 2 water heaters, combined TPR and pan drain line | lfoster | Plumbing Inspections | 11 | 12/18/07 12:23 PM |
| At least they put in a drain line | dbush | Electrical Inspections | 17 | 11/2/07 1:03 AM |
| Evaporator drain line | lfoster | Inspecting HVAC Systems | 3 | 7/18/07 9:35 PM |
| How turns can you have on a TPR drain line? | jlybolt | Plumbing Inspections | 8 | 6/10/07 10:35 AM |
| Dishwasher Drain Line | msimmons | Plumbing Inspections | 9 | 1/19/06 12:27 PM |
