Someone please remind me...is this a mixing valve or a temperature control device of some kind? White is supply, braided is to the single lever lavatory fixture. Anyone have a brand name?
Is it the most remote fixture in the home? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I would need to see more of the pic ,myself.
Where does the top white go? |
Michael B,
Looks like a distribution manifold, may have been installed because the actual mixing valve faucet fixture is defective. Ask him/her if it had distinguishable HOT and COLD at the fixture. In-line mixing valves typically have a control knob or other means of stting the temperature/H C flow
Let us know if you ever find out what it is. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I knew it looked familiar but I didn't have time earlier.
![]() The comfort system pump is installed on your existing hot water heater "hot water line". The system puts hot water in the hot water line instantly, using a pump with a built-in timer at the water heater and a patented bypass valve at the point of use. ![]() Comfort valve installed under the farthest faucet from the water heater. The hot water recirculation pump moves the hot water from the heater throughout the pipe back to the heater through the cold water line. As the water heats up at the comfort valve, it closes. When a faucet is turned on, warm water is instantly available for use with no waste. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Your welcome.
I remember that thread too. I forgot that this device has a back check in it to prevent the cold and hot mixing cold to hot. This does mean that hot water will come out of the cold for a bit though. I would think that would be annoying on a long run. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I have consulted on a house with a similar system but with no timed or other controls. Until I get a separate meter of the tank, I can just guess what the continual losses are.......but my first guess is somewhere between 1-2 kW!! up here that's $2.50 -$5.00 per day!!! |
Not to mention that you still waste heated water until the water reaches desired temp at the end. But hey you do have instant hot at the faucet.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Brian, what you quoted is not mine but the manufacturers lines.
I too think a timer is the better way to go. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
G'night!! |
| Mixing valve question | cmettel | Plumbing Inspections | 2 | 6/17/07 10:03 PM |
| Water Heater Mixing valve? | ccrooker | Canadian Inspectors | 4 | 11/24/06 5:04 AM |
| Manifold connections, mixing valve question | jclark1 | Plumbing Inspections | 14 | 6/15/06 10:46 PM |
