Old 2/25/09, 6:58 PM
Rodney Misener's Avatar
Rodney Misener Rodney Misener is offline
Default MJ fitting on ABS
Heres the situation:
4" ABS waste drain piping in bsmt. One section is connected in a horizontal run with an MJ fitting. Is it required to be suported(the pipe) on either end of the fitting? There is no support 4' + on either side of the MJ fitting.
Rodney Misener, CMI
Trinity Inspection Services
Pictou County, Nova Scotia
http://www.trinityinspectionservices.com
Certified Master Inspector
Certified Level 1 Thermographer
Certified Energy Advisor
WETT eCertified Inspector
IAC2 Radon/Mold Certified
Infrared Certified
Old 2/26/09, 7:36 AM
Frank J. Carey Frank J. Carey is offline
Default Re: MJ fitting on ABS
I am not sure of the support, but I would love to see PT used for the wall plate...
Frank
Carey Inspection Solutions, LLC
Wilkes-Barre/ Scranton PA
Nachi ID -> 08022204
Frank@careyinspectpa.com
www.careyinspectpa.com
www.frankcareyconstruction.com
Old 2/27/09, 4:34 AM
Rodney,
Plumbing pipes should be supported every four foot........in regards to whether it should be supported on each side of the joint would be based upon the weight coming down at that joint. Metal straps are not that expensive.......nor are 2x4 blocks.
regards
Jeff
PS. PT lumber should be used any time that a wood member can come in contact with moisture although if one reads the code carefully, it is possible to fore go PT lumber on still plates depending on the height of the sill plate in relation to the ground.
One of the biggest problems you find with PT lumber are improper fasteners being utilized.....most framers (and DIY's) fail to switch to non-corrosive fasteners when fastening other materials to PT. I have seen many HI's miss such things.......
Old 2/27/09, 5:36 PM
Jeff I agree, but I was only talking about the wall plate on the floor...from a contractors view point.
Good explanation on the supports!
Frank
PB to copper fitting bking Plumbing Inspections 3 8/23/08 1:10 AM
Copper Line Fitting Richard Seay Plumbing Inspections 2 3/27/07 7:25 AM
Whats this pipe and fitting? mtimpani Plumbing Inspections 9 7/13/06 9:47 PM
Flexible Fitting inspector@carolina.rr.com Plumbing Inspections 4 6/9/06 8:05 AM
Contest! Name that fitting! jtedesco1 Electrical Inspections 20 5/30/06 9:16 AM
