Old 4/30/11, 7:24 PM
Rose Wood Rose Wood is offline
Please Note: Rose Wood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Moen 1225 cartridge installtion help
Hi,
I am trying to replace Moen 1225 cartridge. After taking out the cap and small screw from the lever. The lever handle is not coming out. Please suggest me how to take it out without breaking the inside parts. I have tried all possible ways I even spay the silicon still it is very hard to take it out. If you have any link related vedios please let me know. Some reason Moen interactive thing is not working. Any ones help is much appreciated.
Regards
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/30/11, 7:46 PM
Default Re: Moen 1225 cartridge installtion help
Originally Posted by Rose Wood View Post
Hi,
Regards
http://www.nachi.org/bbsystem/viewto...?p=99296#99296
http://www.moen.com/consumer-support...al?id=moen0133
http://www.homeownershub.com/mainten...25-208206-.htm
Larry Kage, CMI
231 929 3525
Old 4/30/11, 9:39 PM
John E. Mullarkey John E. Mullarkey is offline
Did you pull the retaining clip?
Old 4/30/11, 11:52 PM
Gerald C. Wilcox's Avatar
Gerald C. Wilcox Gerald C. Wilcox is offline
The retaining clip has to be removed. They make a tool that fits over the stem that you turn back and forth to loosen the rubber seals on each side of the stem. Once they have broke free from the sides of the faucet body the stem pulls out. The good thing about Moen single lever faucets is that you can correct the hot/left cold/right easily by rotating the stem 180 degrees.
Old 5/1/11, 12:01 AM
Thanks Larry, John and Gerald for your help. I am at initial step. I just taken out the cap and then the small screw after that I am not able take out the lever. Attached is the picture It will give some idea. I appeciate your help.
Regards.
Old 5/1/11, 12:04 AM
Thanks Larry, John and Gerald for your help. I am at initial step. I just taken out the cap and then the small screw after that I am not able take out the lever. Attached is the picture It will give some idea. I appreciate your help.
Regards.
https://picasaweb.google.com/110383268655681002435/Apr302011#5601590925670648082
https://picasaweb.google.com/1103832...90956987240050
Old 5/1/11, 8:17 AM
Moen 1225 cartridge installtion help Rose Wood Plumbing Inspections 2 4/30/11 8:41 PM
Moen Shower Valve - No Retainer Clip Slot Zemke Plumbing Inspections 7 9/24/06 10:02 PM
How to pull out the "Stop Tube" (Moen 1225 cartridge) efang622 Plumbing Inspections 9 5/15/06 12:05 PM
Moen cartridge mlarkin Plumbing Inspections 28 2/15/06 5:37 AM
