Old 1/31/06, 10:51 AM
RGPatrick2 RGPatrick2 is offline
Please Note: RGPatrick2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Mold proff Insulation around Tub
Which is the best insulation to use around a bath tub which is
resistant to mold growth ? (for remodel tub install)
Thanks, Ron
Old 2/1/06, 3:26 AM
Russel Ray's Avatar
Default Re: Mold proff Insulation around Tub
That's an interesting question. I look forward to the responses, of which mine is not one.
Old 2/1/06, 6:34 AM
phinsperger's Avatar
Ron,
I'm not sure why you want insulation around the tub. Are you talking about in the wall behind the tub or in the actual cavity under the steel of the tub?
In general terms mold will grow on just about any surface that remains wet for long periods of time. Organic particles in the air will land on the wet surface and "stick" there as food for the mold to grow.
Having said that, moisture resistance insulation, insulation which does not loose its insulating value when it gets wet, would include mineral wool and most foamed plastics (ie spray foam, XPS, XTPS, etc). There are some others. If you are insulating around pipes and other components that may need future servicing the mineral wool may an option to look at.
Do not use fiberglass (loose fill or batts) or cellulose as these loose their R value when they get wet and all you'll have is a big mess.
Interesting article about mold by litigation. gromicko IAC2 Indoor Air Forum 16 5/5/11 7:48 PM
Mold mcyr IAC2 Indoor Air Forum 5 9/13/10 10:31 AM
CMI imposter? jbraun Certified Master Inspector (CMI) Discussion 118 11/26/07 4:55 PM
Mold Remediation & Duck Cleaning Work-If Done Right dplummer Ancillary Inspection Services & Additional Topics 8 10/12/07 2:03 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 5:25 PM
