Would you consider this type of poly water pipe to be suitable for municipal water install? It appears to be a barb/insert fitting with clamp(s) which is usually thinner and/or lower PSI rating. The typical municipal poly service pipes I see are 200+ psi and CTS with compression type fittings. Any one have any helpful insight and/or documentation on this? Would you mention it? Vary by area and/or jurisdiction? House built in 1997.
Any help is always appreciated!! |
| Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I see it all the time up here...looks fine. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
It's Polyethylene. Very common, especially on well systems. I've never seen it extend inside the house, however. Usually connected to the distribution piping inside the crawl space.
What's unusual is that there is no pressure regulator. Did you take a pressure reading? “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
See the 5th post down here. This is what I'm used to seeing. On well systems, yes this is typical, but not for municipal systems. When using poly, on municipal lines, the piping usually required is the thicker (200 psi) and it is also CTS (Copper Tube Size) which requires a compression fitting as noted above.
I have seen this before where this thinner poly pipe was used as a conduit, but this didn't appear to be.
P2904.4Water service pipe.Water service pipe shall conform to NSF 61 and shall conform to one of the standards listed in Table P2904.4. Water service pipe or tubing, installed underground and outside of the structure, shall have a minimum working pressure rating of 160 pounds per square inch at 73°F (1103 kPa at 23°C). Where the water pressure exceeds 160 pounds per square inch (1103 kPa), piping material shall have a rated working pressure equal to or greater than the highest available pressure. Water service piping materials not third-party certified for water distribution shall terminate at or before the full open valve located at the entrance to the structure. Ductile iron water service piping shall be cement mortar lined in accordance with AWWA C104.
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
