Old 2/26/07, 4:04 PM
bclark's Avatar
bclark bclark is offline
Angry Is It My FAULT?
I just recieved a call from a realtor who I inspected a House for. The client has moved into the house I inspected and his drain line for his washer is not draining. No appliances were present at the time of the inspection. He has had a plumber evaluate the drain line. The plumber used a camera and discovered that there are tree roots growing in the waste line (cast iron). The client is not upset he is just trying to figure out if the home warranty is going to cover this, which it is not. I am not at fault am I....
Thanks Billy,
President, CORE Home Inspections, LLC
"Committed to Excellence"
Visit: www.corehomeinspections.com
Old 2/26/07, 4:12 PM
jwortham1 jwortham1 is offline
Default Re: Is It My FAULT?
I wouldn't think so.
What does your PIA say about underground pipes?
Jeffrey Wortham
ANS Inspections, Inc.
www.ansinspections.com
630.276.8440
638 Langford Drive
Bolingbrook, IL 60440
NACHI ID:04050181
Old 2/26/07, 4:19 PM
bclark's Avatar
PIA please explain
Thanks Billy,
Old 2/26/07, 4:26 PM
gkoehl's Avatar
gkoehl gkoehl is offline
Originally Posted by bclark
PIA please explain
PIA= Pre-inspection Agreement
Where you define the scope and limitations of your service
Basically-
What you can not see, you can not report
George Koehl
Collinsville, TX
TREC# 9435
NACHI ID: 06092190
InTex Inspections
Old 2/26/07, 4:33 PM
bclark's Avatar
Thats what it says. I was worried that maybe I should have taken a garden hose and ran it into the drain line. (Ha, Ha)
Thanks Billy,
Old 2/26/07, 4:36 PM
gkoehl's Avatar
That would have been great when the water started spilling back into the house
George Koehl
Collinsville, TX
TREC# 9435
NACHI ID: 06092190
InTex Inspections
Old 2/27/07, 5:34 PM
wsiegel wsiegel is offline
Sounds like it might be an older home, as the waste lines are caste iron. I have a disclaimer in my report about older caste iron lines and that the customer should have them scoped out due to the reasons you stated. I think only one cleint has followed that advise. Most of them are too cheap to pay for it.
Old 2/28/07, 12:04 AM
Charley L. Bottger's Avatar
Don't laugh Billy thats exactly what I do on a vacant house. I carry washing machine hose with one end cut off and I run water down the drain the whole time I am at the property. Better to back it up during the inspection than after close. There are no questions or worries the line flows or it does not. Sop in this state does not require testing of the washing machine line but I do it anyway always have and always will just my way of cya
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 2/28/07, 12:20 AM
Yes George that is great I would much perfer to mop a little water during the inspection than get a phone call after the close. This just happened to me this last week the main drain was stopped up and back up out of a leaking bathtub drain on a slab floor. I found two problems for the price of saying well I could not see inside of the drain line it is buried. Thats what you have water at the faucets for.
The realtors comment was; Glad it happend now and not after close.
</IMG>
NACHI Member
State License # 130
Old 2/28/07, 7:50 AM
staylor5's Avatar
staylor5 staylor5 is offline
It is crazy to even think that you would be responsible for that. Unless you stuck a camera in the drain line. The amount of tests that we do for plumbing leaks wouldn't cause a main to back up, especally it the house was vacant.
Old 2/28/07, 8:27 AM
Steven; I may be crazy but I don't just check for leaks I as an inspector do feel responsible to my client to ensure the sewer line is flowing to the city connection as intended.
I try very hard to flood the sewer line as every fixture within the home is flowing water during the time I am within the home and this is usually at least 1 1/2 hours inside the home. When I leave a inspection I am going to know if the sewer line is flowing or not. Based on what I observe depends on if a camera scope is recommended or not. I don't recommend a camera scope just for the sake of doing it I need a reason. I don't really care how much water I waste I just do it.
NACHI Member
State License # 130
Old 2/28/07, 9:18 AM
William J. Decker's Avatar
I would pay for a rodding. About $100.00, around here.
Think of the client good will.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 2/28/07, 12:04 PM
bclark's Avatar
I am stumped because I checked all toilets and sinks and tub/showers and they all drained with no problem why is it only showing up on the waste line for the washer. Wouldn't these lines be tied together or seperate.
Thanks Billy,
Old 2/28/07, 5:02 PM
Billy; do you remember the size of the washer drain line diameter. I have experienced the old 1 1/2 inch drains that would not take the pressure/volume from the new type washing machines that need a 2 inch drain to accommodate them. Seller had an old washer the drain worked fine buyer moved in with a new washer and the drain back up on the washer only. But if the plumber found tree roots thats another problem where did he find them.
The washer drain line is going to connect to a larger probally 4 inches before it exits the foundation so what your saying makes not a lot of sense to me????
NACHI Member
State License # 130
Old 2/28/07, 5:34 PM
bclark's Avatar
I think it was the old 1 1/2" Dia. But my question is would the drain lines from the other utilities (tub, shower, toilet, and sink) be seperat from the drain line of the washer. Or would they all tie into one 4" cst iron waste line.
Thanks Billy,
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
Arc Fault combo apolillo Electrical Inspections 13 4/4/07 8:36 PM
Can an AFCI offer GFCI protection gbeaumont Electrical Inspections 19 7/6/06 11:45 PM
Harmonized Ground Fault Circuit Interrupters jtedesco1 Electrical Inspections 5 3/21/06 8:48 AM
