rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Shut off on it's own. Not at the same interval every time.
Thoughts? Yes, I defered to a plumber, just curious as to what may cause this. http://www.youtube.com/watch?v=GP9kg8GjDtA |
| Find an InterNACHI certified New Jersey Home Inspector (and anywhere else in North America) |
I would say a loose cartridge .
if the handle or cartridge is not installed properly this is a common problem Rick....a good plumber should be able to fix that in a few minutes....of course he'll probably charge a million dollars or so.....
Wow my plumber didn't look like that
Definately... I've got a few things around the home that could use some attention.
| double sink drain line config | Scott Schultz | Plumbing Inspections | 3 | 4/22/08 8:03 AM |
| Composite granite kitchen sink ... good choice? | Bill Featherstone | Plumbing Inspections | 6 | 1/8/08 11:03 PM |
| venting the kitchen sink | kblair1 | Plumbing Inspections | 57 | 12/8/06 3:37 PM |
| Sink Clog | dirtydishes | Plumbing Inspections | 26 | 8/27/06 3:48 PM |
| Sink Holes May 13th | zfackler | General Inspection Discussion | 0 | 5/2/06 11:01 AM |
