these were installed on the inlet, outlet and balance line between 2 water heaters installed parallel. date of installation was 1997.
any idea what these are and what their purpose is? Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 3/24/08 at 5:52 PM.. |
Those are just ball valves. They are refrigeration sytle ball valves, however, which are a tad expensive for this use. Under that removable cap is a square stem that you jack open or closed. The installer might have been mostly into refrigeration and had these at hand, or prefers to use them for some reason. If he was using them to balance the system by some means, the selection of this type of valve might have been to prevent tampering. I think that might be a Parker part number, but I'm not sure.
there was a stamping of N2352 on the body of the units.
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
http://us.refrignet.danfoss.com/Tech....F00.A1.22.pdf |
Good Call Marc.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
I just looked at those pictures again and noticed that the installer also used the refrigeration 90's. Must have been a refrigeration guy. What a waste of money.
There may also be a situation with the galvanized pipe coming off the black malible (at the "T" fitting) in picture #1, if that is a gas line.
www.buildingcenter.org Quickly determine the date of manufacture, age or production of most HVAC and Water Heating equipment |
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 9:36 AM |
| TPR & Combusiton Air | thejnicki | Plumbing Inspections | 16 | 9/18/06 8:55 PM |
