Is this aluminum tubing acceptable for use as supply to the water heater. I ask because this is the first time I have run accross it. Thanks for you input.
Rick Slocum NACHI # 04072697 Elizabeth CO 80107 ABSOLUTE Home Inspection Service |
I would think not,and there is no drip leg.
Len |
That particular flexible aluminum gas line is used in automobiles.
Any aluminum or flex tubing installed, should be replaced with rigid gas pipe. This will require the services of a qualified plumbing contractor. |
It also looks like white teflon Tape Not approved in Canada must be yellow teflon tape .
.. Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Thanks guys !! Yeah, I did catch the no drip leg, thanks Len. Thanks David and Roy. I believe this is another "Harry home owner" special , based on some of the other things I found.
That's an old (70's or earlier) rigid-aluminum appliance connector. They were made and listed exactly for that purpose - connecting appliances.
In CA, these are no longer allowed for use, and flexible appliance connectors are now required. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks Jeff
bmargiotti is a non-member guest and is in no way affiliated with InterNACHI or its members.
If it was approved for use at the time, I wouldn't make a big stink about it (provided it's not leaking).
Depends on the local requirements, as always. Flex is used almost exclusively here for most gas appliances.
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 9:36 AM |
| TPR & Combusiton Air | thejnicki | Plumbing Inspections | 16 | 9/18/06 8:55 PM |
| small valve on cold water supply ahead of water heater? | Walt Hoffman | Plumbing Inspections | 6 | 1/23/06 7:44 AM |
