Plumbing drain....
Is this short section with excess drop a real concern? B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I would say no.
I'd concur with Jeff (no surprise there!)
Yet I'd still wonder why not a straight shot? Would there have been too much drop? Looks to be well finished as it hangs...and seems to be a good transition to a slightly larger diameter PVC. - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Solids will get washed right on by that drop would be my thought.
We are looking at 5 feet of pipe so to say proper slope would be wrong with out further info that could be mid point of a 100 ft run and the added bend be used to give added push . If looking at the pipe on either side if the cinder block pillar it shows that part of the run at a good slope.
1/4" per foot I believe is the preferred slope. Does this drain work as installed, most likely, is it a deal breaker, likely not. Will the purchaser fix upon pocession? Likely not.
| Child eviscerated by pool drain | mthomas2 | Ancillary Inspection Services & Additional Topics | 26 | 7/16/07 5:27 PM |
| Maximum slope of drain line? | bsmith | Plumbing Inspections | 6 | 4/16/07 2:28 PM |
| Air leak from floor drain | yolhovsky | Plumbing Inspections | 5 | 2/24/07 7:43 AM |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/17/07 12:04 AM |
| Plumbing drain lines should run downhill at a slope of | darnold1 | Plumbing Inspections | 6 | 2/2/06 10:44 PM |
