Old 3/8/07, 1:48 AM
bwooddell bwooddell is offline
Please Note: bwooddell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Need some help - ABS drain
This is from a brand new house. DWV under a hallway bath with tub/sink/toilet. I about loose count of the 90's. Are there issues with this? I thought there was a code that stated you needed a cleanout when direction changes more than 130 degrees? I also was under the impression that all DWV was supposed to be gradual in turns toward drain. I am looking for help with the issues associated with this DWV image... Thanks...
Old 3/8/07, 7:09 AM
rgiglio1 rgiglio1 is offline
Default Re: Need some help - ABS drain
If the outlet on top is for the tub or sink this is not allowing the toilet to be vented which is illegal. Tough to tell from the picture.
Child eviscerated by pool drain mthomas2 Ancillary Inspection Services & Additional Topics 26 7/16/07 4:27 PM
Air leak from floor drain yolhovsky Plumbing Inspections 5 2/24/07 6:43 AM
French drain tied into main drain rwashington Plumbing Inspections 6 2/16/07 11:04 PM
Exposed drain and plumbers putty tneumann Plumbing Inspections 19 4/27/06 10:57 PM
Washer Secondary Drain roconnor Plumbing Inspections 7 4/2/06 1:02 PM
