Many will know what is shown here but I wanted to post this for those that do not.
There are two extra features plumbed in, do you know what they are? The flex copper is the cold water to a water heater. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Find an InterNACHI certified New York Home Inspector (and anywhere else in North America) |
Nice pic Bruce
Possible water hammer arrestor might be the brass but never seen it on plastic piping. If that's so the other line would be pressure relief. However you could have a water heater return loop.
I personally would be curious of the affects of the plastic pex pipe against the flue.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Not a flue, just a makeup air vent to the attic.
The on/off valve has a pressure relief built in for thermal expansion with the discharge going down to a floor drain. The device on the right is a trap primer that is activated by random small variations in the water pressure. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Bruce, the device on the right is a trap primer that is activated by random small variations in the water pressure.
I agree with Joe.
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
Trap primer?
New to me. What's it do? Tim |
Some slab houses, this one is a 4-unit condo building, have a floor drain in the closet where the water heater and furnace are located. A p-trap is located under the slab and will dry out during the months where no condensate is discharging into it. The trap primer should send enough water to it to prevent sewer gasses from escaping.
BTW, I don't see a drain at the thermal expansion valve. Is it a small Tygon tube? If so, I didn't see it. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
The drain pipe is pex, under the green valve.
Are you talking about old houses that have the laundry floor drain going to the waste? You just need a water supply and a trap primer as shown above. I guess you could put a y-adapter of some sort on the washer supply for the trap primer. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Thanks, Bruce. Learn somethin' new every day in this business.
Tim |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
| Selected Electrical Incidents and Occurrences - First Quarter | pabernathy | Electrical Inspections | 0 | 12/2/07 1:43 PM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
