Old 11/5/09, 10:13 PM
Bob Elliott's Avatar
Default New dish sterilizer on the market
Ok pulling your leg.
This is a TPR valve running from a 30 gal electric that not only runs up hill but also terminates at a faucet type spout in the kitchen sink.
From what I understand all of the water heaters in this one of Chicago's most famous buildings (Marina City) is installed in just this way.
new-dish-sterilizer-market-dsc05877-1024x768-.jpgnew-dish-sterilizer-market-dsc05878-1024x768-.jpgnew-dish-sterilizer-market-dsc05879-1024x768-.jpg
Find an InterNACHI certified Virginia Home Inspector (and anywhere else in North America)
Old 11/5/09, 10:18 PM
Default Re: New dish sterilizer on the market
Attachment 33128Attachment 33129Attachment 33130
Here is a picture of the twin buildings that may help remind you of this structure which holds House of Blues and has been featured in many movies.
Most famous may be when Steve McQueen backed out of one of the open air parking slots that fill the lower floors and in to the Chicago River in Man Hunter.
Old 11/5/09, 11:45 PM
Chuck Evans's Avatar
Air gap to an indirect waste receptacle. Certainly located where it would get noticed if it discharged.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 11/5/09, 11:57 PM
Water heater TPR valve should never discharge into the sink, tub, shower stall, etc. Emergency discharge of hot water / steam might cause severe injury. Keep the discharge pipe low, always pointing down and within 6″ from the floor level – you may also pipe it directly into the floor drain.
Discharge pipe from the water heater TPR valve must always run downhill- if the TPR valve opens occasionally, and water / steam instead of being drained, accumulates / floods the valve, it might eventually cause its corrosion, and prevent it from functioning properly or at all.
Copied off check this house .com
Old 11/6/09, 2:54 PM
Jeffrey R. Jonas's Avatar
No, you may not. Just because you read it on the internet, doesn't always make it so.
Old 11/6/09, 3:05 PM
I take that to mean in a basement with 6 inch gap.
Do you consider it ok to run uphill ?
Do you see any issues?
Do you feels into a kitchen sink is ok?
Do you ever take advice from members of this forum (internet) ?
Old 11/6/09, 3:24 PM
I take that to mean in a basement with 6 inch gap. That's not what you wrote. In that case, yes okay.
Do you consider it ok to run uphill ? Never
Do you see any issues? Yes
Do you feels into a kitchen sink is ok? No
Do you ever take advice from members of this forum (internet) ? Only with a grain of salt
Old 11/6/09, 3:30 PM
OK then.
Old 11/6/09, 10:10 PM
Brian E. Kelly's Avatar
What??? Nice one Jeffrey
Old 11/6/09, 10:37 PM
Who cares what you think?
You are on the internet.
Old 11/6/09, 11:49 PM
I never said that it was OK to run it uphill, or to use the flexible connectors for discharge lines, for that matter. I also suspect that the spout is less than full diameter of the valve discharge. Considering that the only way to route it from below the sink into the sink is to run it uphill, then the installation is not proper. However it does have the required features that I did mention in my post.
Also, as was indicated by others "check this house .com " is hardly an authoratative source for installation standards (might as well quote HG TV). You might reference appliable codes (I know you are not a code inspector) or manufacturer installaton documentation.
Houston, TX
Old 11/7/09, 1:51 AM
Spout is a smaller diameter,good point.
Inspecting NY is not official code either but I bet most of the guys here go there for last minute info.
Sorry if Check this house angered anyone but the info is correct.
Home Sales Tumble Again, Hopes for a Bottom Fade jburkeson1 Miscellaneous Discussion for Inspectors 24 12/26/08 11:57 AM
How crazy has the Toronto Real Estate Market become? cmettel Canadian Inspectors 4 6/11/07 2:29 PM
SoCal Housing Market Holds its Ground whandley Miscellaneous Discussion for Inspectors 0 5/3/07 12:12 PM
Hot market hurting home inspections rwand1 Canadian Inspectors 9 5/25/06 7:35 AM
