Old 1/5/08, 10:18 PM
Chris Miles Chris Miles is offline
Please Note: Chris Miles is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default New water heater install
I am going to be installing a new water heater tomorrow and have a question about which water lines to use. Are the copper lines that are sweated together going to last longer than the steel braided lines that attach to unthreaded copper lines with compression fittings? The steel braided flexible lines will be easier to install, but easy is not always better.
Old 1/5/08, 10:31 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Default Re: New water heater install
If your experience level is average I'd go with the flex line.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 1/5/08, 11:32 PM
Christopher Currins's Avatar
What Jack said. The steel braided lines have copper lining.
Christopher Currins
Certified, Licensed
Old 1/7/08, 5:19 PM
I went ahead and installed it with the flex lines with the compression fittings. I was wondering how reliable they are compared to the copper pipe.
Old 1/7/08, 6:10 PM
The flex lines will probably last as long as your water heater.
Abraham Lincoln
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 8:55 PM
