Old 5/5/10, 5:39 PM
Timothy H. Barnett Timothy H. Barnett is offline
Default Newbie question!
Two things today I wanted input on...sink trap and water heater vent pipe...
Concern or no? The vent pipe is double wall pipe as it penetrates the ceiling and there is over 6 inches on all sides from wall board.
Thanks!
Timothy Barnett
Acclaim Home Inspections, LLC
Wadesville, IN 47638
Indiana Lic. #HI01000020
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/5/10, 6:23 PM
Jeffrey R. Jonas's Avatar
Default Re: Newbie question!
Welcome Tim!
The trap "may" be an issue. Got another pic from the left side?
Assuming the ID of the flue pipe is constant (single wall/dbl wall), I see no issue.
Jeff
Old 5/5/10, 7:07 PM
That's the only angle I got. It is what I would describe as an "S" trap, even though it's not a typical straight "S." It appears to be done for clearance issues inside the cabinet. Should I note it as a major or minor concern?
Timothy Barnett
Old 5/5/10, 10:04 PM
Jeffrey Moore Jeffrey Moore is offline
Tim,
You could call the drain configuration as unusual and defer or just recommend replacement.
I would be a little concerned that the flue interior diameter changes in size in the transition from single to double wall.
Jeff Moore
www.quantumhomeinspections.com
Flir (ITC) Level II Thermographer
Mesa, AZ
Old 5/5/10, 11:37 PM
James F. McKee's Avatar
an extension tailpiece on the sink drain would have allowed for a more conventional trap set up i saw no major issues on the hwtvent....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 5/6/10, 10:42 AM
Thanks for the responses. I noted it as an "S" that needs attention/replacement. The HW vent I didn't not draw out, other than to emphasize keeping combustibles out of this area! (ie "Don't lay your laundry on it to dry!!!)
Thanks again, great to have a place for these newbie quesions until I get more comfortable making the calls on my own!
Tim
Timothy Barnett
Old 5/6/10, 12:38 PM
Michael Larson's Avatar
The drain is effectively an S-trap and should be replaced.
The single wall portion flue pipe may be too close to the combustible wall.
Do you have a dimension?
Michael Larson
Hudson, WI
Old 5/7/10, 12:00 AM
Chuck Evans's Avatar
Tim
Good call on both items.
As mentioned, previously a tailpiece extension will allow reconfiguring of the trap.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Newbie question tlarsen Miscellaneous Discussion for Inspectors 13 3/31/09 10:43 PM
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 1:04 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Question from a Newbie for you "seasoned" Inspectors gbrasseur General Inspection Discussion 7 3/13/07 4:30 PM
