Old 6/10/07, 7:15 PM
Sabrina J. Roper Sabrina J. Roper is offline
Please Note: Sabrina J. Roper is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Nitrogen Dioxide, Nitrogen Oxide Question Please
Hi All,
I have a question that maybe someone here may be able to answer for me.
This question is about the same used gas water heater I posted about last month titled:
Burnt Combustion Hatch? Please Help!
http://www.nachi.org/forum/f22/burnt-combustion-hatch-please-help-17335/
The gas water heater was shut down for a week. We put a door up to the room where the gas water heater is located which this room is attached to our kitchen. After we put this door up we re-lit the gas water heater and it has been lit for a week and a half now. The vapours are still getting into the apartment even with a door put up to block off that room.
My landlord still has not replaced the durn thing even tho we are still having problems with it....and now I have developed Respiratoral problems.
I've done more reseach on gases that a gas water heater can put out which are Nitrogen Oxide and Nitrogen Dioxide, both from which I read can cause burning of the eyes, nose and throat and Respiratorial (fluid in lungs) problems.
I would like to know who I could call who would be able to detect Nitrogen Oxide and Nitrogen Dioxide in my home?
Would I call the City? Or who should I call?
Thank You,
Sabrina Roper
CC, TX
Old 6/10/07, 7:21 PM
Default Re: Nitrogen Dioxide, Nitrogen Oxide Question Please
You may consider the fire department if you think you are breathing poison and can't seem to stop it.
Larry Kage, CMI
231 929 3525
Old 6/10/07, 7:22 PM
Ted Allen Ted Allen is offline
Originally Posted by Sabrina J. Roper
Hi All,
Thank You,
Sabrina Roper
CC, TX
Call the local Gas company and if there is a problem they will red flag the system, and turn off the gas until it is fixed.
Old 6/10/07, 7:24 PM
Brian E. Kelly's Avatar
Draeger tubes should do the trick.
http://www.afcintl.com/tubeio.htm
Old 6/10/07, 7:25 PM
Originally Posted by bkelly2
Draeger tubes sould do the trick.
Oh, hell Brian why not make this difficult?
Old 6/10/07, 7:28 PM
It's all relative Todd, I answered the question, you chose to go with "Reccomend further evaluation bla bla bla...............".
Old 6/10/07, 7:30 PM
Yes, but sometimes they ask the wrong question and don't even know it.
Larry Kage, CMI
231 929 3525
Old 6/10/07, 7:32 PM
In all cases conserning Natural GAS the local GAS company is the folks that should deal with it, and they will.
Old 6/10/07, 7:34 PM
I do not think you answered the question. As the question was ...... Who should I go to and not what far out test should I use... LOL
The gas company rocks and they take care of all problems post haste.
Old 6/10/07, 7:39 PM
It's cause you are a wire puller Todd.
Old 6/10/07, 8:07 PM
Sabrina, as has been said on your earlier posts, the vent piping to the water heaters is WRONG. Todd is correct and you should call your local gas company to come out and evaluate your situation.
Old 6/10/07, 8:20 PM
I will call the gas company tomorrow morning and request help. Not to sure if the City will have anything to detect something like this, but worth a try.
These Draeger tubes you speak of, how are they use? Do you fill them with a solution and stand in the area you think has the vapour and the liquid in the tube changes color?
I know stupid question
Thanks Sabrina
Old 6/10/07, 8:22 PM
Thanks Sabrina
Have no fear, if you explain the problem to the Gas company they WILL deal with it.
Old 6/10/07, 8:26 PM
Jeffrey R. Pope's Avatar
If you're gonna keep screwing around with this totally-inadequate-installation, you may as well just call the local mortuary and reserve your plots. . .
Shut it down until it's fixed. Call an attorney in the morning. As a tenant, you have rights. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/10/07, 8:32 PM
Thanks Sabrina
http://www.draeger.com/ST/internet/p...re_tubes_e.pdf
Testing with Draeger tubes falls well outside of the realm of Home Inspecting Sabrina, the gas company may have them. A large Gas/Chemical supplier may have them in your area, Air Products, Linde, Praxair, Air Liquide etc.
Another reason to recommend CO testers rnewman1 Interior Inspections 2 10/12/06 7:47 AM
