I was installing a dishwasher for a friend of mine this evening and while looking through the directions it made no mention of a high loop. An air gap diagram was present but it said only required by AHJ or local codes.
According to WHirlpool there is no need for a high loop.. Any comments?? Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What was the retail price of the unit?
It seems that the ones that cost over $500-$600 have the high loop built in. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Some models do not require them.
Pretty is to do if not sure. |
This Whirlpool Manual does.
Drain Requirements ■ Connect drain hose to waste tee or disposal inlet above drain trap in house plumbing. ■ Connect drain hose to house plumbing 20" (50.8 cm) minimum above the floor. NOTE: It is recommended that the drain hose either be looped up and securely fastened to the underside of the counter, or be connected to an air gap. ■ Use a drain air gap if the drain hose is connected to house plumbing lower than 18" (45.7 cm) above the subfloor or floor. Drain Air Gap And so does their most expensive model, $999.00 http://www.whirlpool.com/catalog/category.jsp?Ns=PRODUCT_PRICE|1&N=0&cat=108 Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
BTW it was a cheap model. quiet partner 1 i believe.. SO unless its a code for an air gap it aint a requirement only a recommendation. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
If the IRC applies in your area a high loop is required.
P.S. In addition, the supply line needs to be protected by an air gap or backflow preventer, which is usually built into dishwashers. Perhaps the mfr meant an air gap on the supply isnt needed. Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 6/16/11 at 11:16 AM.. |
How long does it take to install a clamp and anchor the flexible drain line beneath the counter? Maybe 2 minutes... maybe less? Sure is a helluva lot less time and effort than gets invested in determining whether it's required or recommended...
My opinion... who cares whether the jurisdiction requires it or not... just do it! Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
prolly no requirement for a toilet seat either....do You want one or not?
Digging up this old thread because I got a call to explain what I meant by "Dishwasher does not have a sufficient high loop to prevent drain water siphoning back into dish washer unit.
I have called this out many many times and have never had to explain what I meant. I provide a photo of the defect and include an arrow demonstrating where the loop should be mounted. Just wanted to share than no matter how clear you think you are, sometimes someone will not understand. I know some models do not require a high loop as they have an air gap built in but I call them out every time I see them under the sink. It's such an easy fix I am surprised anyone cared. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
"No command or order is so simple that it cannot be misunderstood" |
I include a picture of the drain hose in every report.
Must be more wast of time the 10 page report guys all hate. |
ctasker is a non-member guest and is in no way affiliated with InterNACHI or its members.
I posted a while back about the loop, because I have been seeing New homes without the loop, seems like the same models with integral back flow preventer. spoke to a plumber who claimed he had been installing without a loop for a while .
Just curious what models have a built in air-gap on the discharge, becuase I havent come across that yet. Many have built-in protection on the supply side, but not on the discharge side. Are those special models for areas still on UPC codes (like CA) that require an air gap instead of a high loop on the discharge?
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
You have no way of memorizing so just do yourself a favor and recommend for all. Easy to do and an argument is a waste of everyone's time. |
I write it up every time. But I also teach home inspection, so I like to be aware of exceptions to the rules ...
| Air gap or high loop | bhartley | Plumbing Inspections | 23 | 11/20/09 12:50 PM |
| Liability question | jcahill | Legislation, Licensing & Legal Issues for Inspectors | 30 | 8/24/08 4:10 PM |
| High Loop | bkelly2 | Plumbing Inspections | 10 | 7/19/06 10:26 AM |
