Working on a report for an inspection I just did this evening...As I was working on the report, it dawned on my that there was no plumbing vent on the roof. After reviewing photos of the roof, and the attic I confirmed that there were none. Not only no vent in the roof, but not venting into the attic either...
How would you report that? Obviously that there was no plumbing vent, but what else would you say beyond that? Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I'd simply state that no vent was observed or verified and leave it at that Mark ...why complicate it with something you are only guessing at?
Cheers, Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
that is exactly what i meant by complicating it... |
mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
I believe you are better off complicating it to be sure that there is a vent otherwise you face the possibility of a call back if the client finds out down the road. Maybe offer to go back to the home and look for the vent, unless you are sure there is no vent.
Report it , if you can not find it. it may be under the insulation. Did you see any air admittance valves ? How old was the home, Was there p traps or s traps?
did everything flush? no gurgling ? if not the vent may be in a wall hidden by insulation. i do not think you are complicating anything your doing your Job. Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
James,
What would you report? Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
FWIW I think Marcel has got it.
It reports the potential defect and warns of consequences if it is not vented correctly. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
If an open plumbing vent terminated high in a wall or under fiberglass batts in the attic and its continuation was simply forgotten/missed by the installer, in all likelyhood, drainage and the traps would still function but.....on certain days, sewage odour may be evident in the home or attic. |
I had this one awhile ago
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
I re-reading this Marcel i'm not really sure... it would depend on a couple things.... When i read the initial post I understood it that Mark realized after he had left the property He didnt have a picture of the vent stack and couldn't actually remember seeing one....In the couse of an inspection i will fill, drain and flush a good number of things and usually get a pretty good idea on how the drain system is functioning at that time. If everything is functioning properly and flowing freely I probably would not make a big deal out of the fact I missed a picture of the vent stack. On the other hand if at the property during the inspection I looked for and could not find a vent termination I would treat that situation much like your statement.... |
You are complicating things Cheers, Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
That's why I have trained for a number of housing/energy related groups including homebuilder, home designer, architect, appraiser, heritage, IAQ, power, WETT, energy auditing, realtor entities Last edited by Brian A. MacNeish; 7/17/10 at 11:03 AM.. |
So, how would you word it? Cheers, Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
| Plumbing vent | cbono | Canadian Inspectors | 23 | 10/13/07 10:58 AM |
| Plumbing vent next to exhaust vent | mpettitt | Plumbing Inspections | 5 | 10/12/07 5:38 PM |
