First time I have ever seen a natural gas meter with no visible pressure regulator, is this application acceptible in other areas? Sorry No photo..
I just went outside and looked at my own. Pipe comes from the city from underground, then to a valve, then the regulator, then the meter, and finally into the house.
You said 'no VENT', not no regulator so thats confusing. I must assume a regulator is upstream of the house but I would write it up. Peter Siposs Absolute Home Inspections Home, Mold, IAQ, Radon, & Lead Based Paint Liberty Lake, WA Serving Eastern WA & Northern ID Nachi# 05100181 peter@absolute-home-inspections.com |
Sorry, around here the regulator has a vent built into it for excess fumes.
Some of the newer meters have a vent/regulator/diaphram built into the unit. You'll see the screened vent at the bottom of the inlet side of the meter.
| Plumbing vent next to exhaust vent | mpettitt | Plumbing Inspections | 4 | 10/12/07 6:38 PM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 10:17 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 6:22 PM |
