Old 6/19/10, 1:22 AM
zswieca zswieca is offline
Please Note: zswieca is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default not sure what it's
Don't come across to many of these, not sure what it's.
Thanks in advance for your help. It is used to fill swimming pool with water.
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/19/10, 8:22 AM
Default Re: not sure what it's
Originally Posted by badair View Post
Pressure Vacuum Breaker (PVB) for back flow prevention of the pool auto fill system or possibly irrigation system...i wasn't there to test either system
Barry's got it.
Nice to see ya, Bear.
Larry Kage, CMI
231 929 3525
Old 6/19/10, 7:14 PM
Brian E. Kelly's Avatar
the green yellow thingy is a water Timer i think
Old 6/20/10, 12:53 PM
Jim Kolke's Avatar
Jim Kolke Jim Kolke is offline
Larry got it right~ definitely a vacuum breaker. In illinois that is against code. All in ground spinkler systems or pool supplys must use double rpz check valves and must be tested annually. This vacuum breaker might be ok in yous state.
