I looked at a water heater TPR pipe, air handler condensate pipe, and clothes washer waste pipe all leading to one drian pipe. Pay particular attention to the T-fiting on the TPR pipe and the condensate drain pipe. Could this cause a problem?
John J. Passailaigue Jr. NACHI05062580 Auburn Home Inspection Auburn, Alabama WAR EAGLE!
IRC P2803.6.1
"The discharge piping serving a pressure-relief valve, temperature relief valve or combination valve shall: 4) serve a single relief device and shall not connect to piping serving any other relief device or equipment. 12) Not have valves or tee fittings." The condensate drain for the AC needs to discharge in such a way that it can be monitored. With the exception of the washer, it's all wrong. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
brepanshek is a non-member guest and is in no way affiliated with InterNACHI or its members.
I saw once that the TPR valve tube ran down to the floor, along the floor about 3' then tied into the a/c condensate line (also 3/4") that then went 1' to a floor drain. Is this not correct either??
[img] http://www.contractortalk.com/attach...1&d=1165186365 [/img] |
Marc I can't open the image
Opps, I should have call the last inspection that I saw this on. What would you do if you sent out your report and remembered or learned of something like this, do I call up the client and state my new findings????????
Brian, the work in my above picture did pass the AHJ's plumbing inspection without a fuss. I posted that pic only because it does seem to violate the letter of the code. That's only my opinion. I might be muddying the waters with information beyond the scope of what you normally do, so I'm sorry about that. It's just interesting to discuss, is all.
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have learned things after an inspection...next day.....and I called them and mentioned it....then they wanted an addendum..which I wrote and printed as a pdf file, uploaded to HomeGauge and it became part of the report.
