Old 8/19/09, 9:19 PM
Tim Larsen Tim Larsen is offline
Default Is this okay?
Saw this arrangement today. Does this need more venting where the
top waste line drops in? It is the laundry waste line, which is vented fine on the other end.
TIA,
Tim
Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America)
Old 8/19/09, 11:56 PM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Is this okay?
Does that PVC connect straight down into ABS?
http://www.inspect-ny.com/plumbing/1623s.jpg
Old 8/20/09, 8:27 AM
It does, Mark. Already called that. Good eye, though.
Just wondering about the unvented drop. The laundry trap is about 8' feet away.
Tim
Old 8/20/09, 8:04 PM
jsupley jsupley is offline
Should be vented as high as possible,, is there a washing machine on the side that looks to be 2". If so thats not proper, it will blow waste water straight through to the other fixture.
Old 8/20/09, 9:57 PM
Marcel Gratton's Avatar
TIA,
Tim
If the top drain pipe in your pic is for the washer and is properly vented at the other end, I see no need for more venting.
On The Level Inspection
Gatineau, Québec
Old 8/20/09, 10:28 PM
In the plumbing world you dont wash a major past a minor fixture. A washer being a major and sink or any other fixture which is not emptied via pump, with the exclusion of a toilet which may or may not be considered a major depending upon local building officials. They keep reverting back to old code when it suits them.
Old 8/21/09, 8:12 AM
Thanks, Marcel. I thought so, but just checking.
Tim
Old 8/21/09, 11:41 AM
Rick K. Kie's Avatar
Rick K. Kie Rick K. Kie is offline
I agree you cant see the other end of the pipe. It could have: An auto vent, A loop vent or it could connect to the stack in the attic. We cant tell from this one picture.
Rick Kie
Old 8/22/09, 8:57 AM
I could see the vent on the other end. It was exposed for part of the wall.
Tim
