Old 12/8/08, 9:20 PM
bwilliams bwilliams is offline
Default Outside Hot Water Heater With Vent Pipe Outside Kitchen Window
Hello again,
I found a situation that I need some clarification on. An enclosed outside water heater has a solid vent pipe that begins one foot below and away from a kitchen window that can open. The solid pipe extends all the way up to the roof and is a minimum of two feet above it. It is properly capped. The placement of the water in front of that window was done because of lack of space elsewhere and moving it would be really expensive.
How would you call it?
Bradley
Old 12/8/08, 9:23 PM
Jeffrey R. Pope's Avatar
Default Re: Outside Hot Water Heater With Vent Pipe Outside Kitchen Window
I don't see it as an issue.
It's enclosed and (from what you've stated) properly vented. What's the problem?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/8/08, 9:49 PM
Chuck Evans's Avatar
Originally Posted by bwilliams View Post
Hello again,
Bradley
Unsightly
Make sure it's properly braced / supported and has adequate clearance from combustibles
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 12/8/08, 10:21 PM
I guess the proximity to the window and possible CO leakage into the home.
Bradley
Old 12/8/08, 11:10 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Ok so it's enclosed and vented above the roof. Why would this be any different than a water heater installed in an indoor utility closet or room? Not a problem as I see it.
Stephen Stanczyk
Gas Water Heater Flue Pipe Connected To Plumbing Vent Pipe bwilliams Plumbing Inspections 6 8/7/09 10:32 PM
Proper gas water heater vent pipe hmcbride Plumbing Inspections 4 10/26/08 4:23 PM
Gas water heater vent pipe? pcloninger Plumbing Inspections 5 2/1/08 6:17 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
Rinnai Water heater vent kelliott Plumbing Inspections 24 9/11/06 10:40 PM
