Old 1/26/08, 1:15 AM
gporter's Avatar
gporter gporter is offline
Default Outside Spigot
Should the piping as seen in this pic be showing. Or should it be covered by stucco.
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 1/26/08, 2:07 AM
Barry Adair's Avatar
Default Re: Outside Spigot
Gary,
It's a miracle, they actually tooled a sealant joint around the sillcock..looks good the way it is from here...but FL is a different world especially Disney City
Why is the stucco in the grass?...block or concrete?
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 1/26/08, 8:54 AM
Doug Edwards's Avatar
Was going to ask the same question. Is this EIFS?
Old 1/26/08, 9:32 AM
Oh no not that Everything Is Failing Severely material, bet there's that new black gold behind it
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 1/28/08, 8:52 PM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
That actually looks like something someone made up out of a boiler drain.
In my neck of the woods ,where it freezes in winter, we use frost proof /anti-siphon hydrants that have a plastic flange that screws to the wall leaving no visible pipe.
Does florida require anti-siphon hydrants? That one appears not to be.
Old 1/29/08, 8:29 AM
It looks like it may have something like this
Vacuum Breakers permit the attachment of portable hoses to hose thread faucets and prevent the reverse flow of polluted water from entering into the potable water supply due to backsiphonage.
Larry Kage, CMI
231 929 3525
Old 1/29/08, 8:47 AM
Thank you Mr.Kage.
Old 1/29/08, 9:39 AM
Perhaps things are done differently a hunnert miles north of here, but in this area we don't use EIFS (thankfully!), and the hose bib looks to be a normal installation.
Abraham Lincoln
Old 1/29/08, 4:03 PM
sparksnmore sparksnmore is offline
Please Note: sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
We still see a few of those around although most of them have been replaced with freezeless hydrants.
It's actually a MIP boiler drain screwed into a FIP fitting (maybe a 1/2 galvanized coupling) being used as a sillcock.
About the only difference between a boiler drain and a sillcock is the sillcock has a flange with screw slots and female threads.
It's supply pipe has to be shut off and drained in cold weather anyway so other than aesthetics, it really doesn't matter how much of it is hidden.
Don't lean on that tub spigot. gromicko Plumbing Inspections 5 3/1/06 9:58 PM
water pressure test msaxton Plumbing Inspections 27 2/12/06 11:58 PM
