Old 1/3/11, 1:00 AM
Stephen P. Shockley's Avatar
Stephen P. Shockley Stephen P. Shockley is offline
Default Overflow drain for water heater
Has anyone ever come across an overflow drain system for a water heater like the ones in the photos? I don't see anything wrong with it because most of the homes I've seen so far don't go this far, but would like to hear some other views on this.
Thanks,
Steve
overflow-drain-water-heater-bennetts-123010-083.jpg   overflow-drain-water-heater-bennetts-123010-254.jpg
Shore-Footed Property Services, LLC
Stephen P. Shockley
MD Licensed Home Inspector
410-726-3471
Salisbury, Md
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/3/11, 1:05 AM
rsmith24 rsmith24 is offline
Default Re: Overflow drain for water heater
I Don't like it.
INSPECTIONLOGOS.COM
"I can keep explaining it for you, but I can't understand it for you".
Nick G.
Monroe Home Inspection
Old 1/3/11, 8:46 AM
Joe Funderburk, CMI's Avatar
Are they using the line as an indirect waste receptor for the TPRV? The discharge point should be outside the building and I presume it's going in the crawl, which is a no no.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 1/3/11, 8:55 AM
jwood2 jwood2 is offline
My question would be Is that a proper air gap?
Soon to be an Inspector Knowledge is Power
tilemontana.com
Old 1/3/11, 9:04 AM
James H. Bushart's Avatar
Air gap?
Explain your question, please. Are you suggesting backflow from the hole to the drain pan?
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 1/3/11, 11:27 AM
Robert Bourdage Robert Bourdage is offline
That looks like 3/4 inch PVc piping which should not be used on a TPR valve because this pipe is not rated for that application.
Old 1/3/11, 1:13 PM
agallatin agallatin is offline
This is correct (no PVC) , and yes there is not a proper air gap !
galaxyhomeinspections.com
An amateur built the Ark !
Professionals built the Titanic !
Old 1/3/11, 1:30 PM
Looks like CPVC to me.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/3/11, 8:05 PM
Joe,
The answer to your two questions is yes they are using it as an indirect waste receptor for the TPRV and yes the discharge point is in the crawl space.
Regards,
Steve
Stephen P. Shockley
410-726-3471
Salisbury, Md
Old 1/3/11, 8:33 PM
Thanks everyone for the comments. I think I know what I'll do with this now.
Regards,
Steve
Stephen P. Shockley
410-726-3471
Salisbury, Md
Old 1/14/11, 7:45 PM
Marc-Andre Beauchemin's Avatar
Marc-Andre Beauchemin Marc-Andre Beauchemin is offline
I don't like it either!
Old 1/14/11, 8:12 PM
Bob Elliott's Avatar
You should be able to see the end of the TPR opening.
How would you know if it is leaking and also dumping drains into dirt under the crawlspace is not proper.
Old 1/16/11, 4:19 PM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
The line should exit the home .
Old 1/17/11, 12:16 PM
Sean Fogarty's Avatar
Dumping water into the crawl would create an issue all on its own, but if the water heater is either leaking from one or both sources then you would have other issues to deal with.
As for a level of importance, what are the chances it will leak? I would mention it but it would not be of big importance. The worst that could happen is a wet crawlspace.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Condensate Drainage jevans Inspecting HVAC Systems 28 11/27/10 2:55 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
