Old 5/2/08, 9:45 AM
Kevin L. Bell Kevin L. Bell is offline
Please Note: Kevin L. Bell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default P-trap lower than drain line?? Help.
Hello to all that read this,
I have a home built in 1961 and due to flood damage had to replace my bathroom vanity. I purchased a new vanity and it was not until it was bolted in place and a new faucet installed that I noticed the inside of the vanity is much higher than the previous one. The potential? problem I have is that the ptrap must be higher than the drain line. Will that be a problem?
Thank you in advance!
Old 5/2/08, 9:51 AM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: P-trap lower than drain line?? Help.
Have any pics? Seems like you may create an "S" trap that would not be proper.
Simple fix is to extend the outlet from the sink so the P-trap is at proper height.
Old 5/2/08, 9:57 AM
Seems like you could extend the sink drain tail piece or raise the drain line where the trap arm enters it.
Just a guess without pics...
Larry Kage, CMI
231 929 3525
Old 5/2/08, 9:58 AM
Barry Adair's Avatar
Ditto what everyone has said
Tail piece extension ought to get the trap in the proper location if I'm understanding what you're describing.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 5/2/08, 10:08 AM
Hi,
The problem is that I cannot get the trap lower than the drain line because of the inside of the vanity. What I mean to say is that the clearing between the drain line and the inside/bottom of the vanity are very close and there is no room to connect the ptrap to be lower than the drain line. .... Would I be able to raise the drain line with a 90 to relocate it higher then I can have the trap lower? I cannot do anything with the main drain line behind the cement, other than put on a 90 going up.
Old 5/2/08, 10:14 AM
Hi,
Pix required, I'm lost
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 5/2/08, 10:17 AM
rmaday's Avatar
Ah - different problem.
How much distance is between the floor and the drain line?
How much distance between the floor and the "new" bottom of the vanity?
You may consider lowerng the bottom of the vanity interior if possible.
Old 5/2/08, 10:20 AM
http://s79.photobucket.com/albums/j1...t=untitled.jpg
Old 5/2/08, 10:21 AM
rmaday's Avatar
I think the configuration is as follows:
(from bottom)
Floor
<gap>
Vanity bottom
<no clearance>
Drain line exiting bathroom
What it should be is...
Floor
<no gap>
Vanity bottom
<clearance>
Drain line
Old 5/2/08, 10:22 AM
rmaday's Avatar
What is that distance?
Old 5/2/08, 10:24 AM
I cannot lower the vanity because it has a bottom drawer. The distance of the line to to floor and floor to vanity - not sure and I am not in front of it. If I had to guess I would say the floor to line is 12" or less and floor to vanity (inside) - maybe 7+"?
Old 5/2/08, 10:29 AM
Essentially, when I place the trap in, its drain line - to connect to the main drain line - sits exactly on top of the main drain line. So the distance I need is to be able to drop the trap darin line the width of the main line - inch and a half copper line. But I have nowhere to gain this 1.5 inches so the trap can fit correctly underneath the drain line.
Old 5/2/08, 10:32 AM
rmaday's Avatar
Pic sure would help.
Old 5/2/08, 10:34 AM
http://s79.photobucket.com/albums/j1...t=untitled.jpg --- I hope you can you see this.
Old 5/2/08, 10:46 AM
rmaday's Avatar
Saw that - I was talking about an actual photo of the situation.
Slope of waste drain line. mlong Plumbing Inspections 5 4/23/08 9:54 PM
double sink drain line config Scott Schultz Plumbing Inspections 3 4/22/08 8:03 AM
W/M drain trap below the floor rbrady Plumbing Inspections 3 1/22/08 11:51 AM
Potable Water Line to Trap jcooper2 Plumbing Inspections 9 11/1/06 12:17 AM
