Is it a common practice for the p trap to be in the slab? Under the kitchen sink and whirlpool tub there is no p trap. House built in 05' and there is no smell, so I assume I just can't see it.
Colton Hagler LSBHI #10760 Scope Home Inspections Colton@ScopeInspections.PRO www.ShreveportHomeInspections.net Home Inspector Shreveport |
| Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
No, it's not a common practice, and not likely to be in the slab. Generally, the only traps that will be in the slab are those of stall showers and bathtubs.
I would (at minimum) suggest verification that appropriate traps are present. I think you'll find that they are not. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Condensation Drain line question | acassady | Inspecting HVAC Systems | 25 | 2/26/12 11:40 AM |
| S-Trap? Part2 | wmisegades | Plumbing Inspections | 9 | 12/12/11 8:07 PM |
