Someone painted the electric water heater at a ceiling unit to blend in and I was wondering if this should be considered OK or an issue ?
[ATTACH] [/ATTACH]
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Usual but I see nothing wrong with painting it.. Roy
Roycooke@hotmail.com I prefer E-mail "All that is necessary for the triumph of evil is that good men do nothing"----- - -Edmund Burk |
I don't see a problem with painting the skin of a water heater. Black is a new appliance color these days.
Are you going to tell me it voids the warranty? LEED Green Associates Inachi US Member of the Year Award 2009 Best Home Inspector Software http://co.nachi.org/inachiawards |
Paint it like a rocket and put a cone on top! Now that would bring some attention. LOL
THE RIGHT TRAK CIAQP, IAC2 Board Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq apoteyes@gmail.com Cell: 705-971-2096 Ph : 705-946-2676 |
Never see it done but was stressing to think of a reason though may call out the painted B vent on the gas furnace ....hmmm ?
Please do not say it is OK. |
Depends on the paint used
Government is the great fiction, through which everybody endeavors to live at the expense of everybody else. -- Frederic Bastiat |
Juan Jimenez
A House on a Rock Home Inspections LLC God. Family. Home. 571-208-3286 http://ahouseonarock.com Richmond, VA Home Inspector Richmond, VA Radon Tests Recommend US! http://www.facebook.com/RichmondHomeInspector |
Yeah was waiting for that one.
Actually flue I was referring to was from earlier that day and was a guy going crazy with a paint sprayer over a whole basement (190 Doubt it was high temp rated...more like semi gloss. Worst part about water heater was lack of identification tag (may have been painted over). |
We did not see all of that in the pictures you submitted.
I guess you answered your own question posed here. Huh! LEED Green Associates Inachi US Member of the Year Award 2009 Best Home Inspector Software http://co.nachi.org/inachiawards |
Flue was obvious though. For some reason the electric water heater flue was missing... Now thinking back have I read about water heater tanks (gas ) needing clearance from combustibles ? hmmmm. |
The way I see it, its no different than putting an insulated blanket over it:
· Investigate: The water heater is encased with an insulation blanket. This was a recommended practice before water heaters were self-insulating. Although, this may seem like a good thing, it actually prevents one from reading the many warning labels on the unit. Further, it obstructs my view of the unit and does not allow me to make assessment of the condition. Water heaters typically last 8-12 years. We recommend you inquire with the seller as to the age of the unit and make appropriate plans to replace the unit if it is nearing the end of its service life. Marcel Gratton, NACHI04011210, CMI, NHI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
What if the paint is flammable ? after all water heaters are required to have clearance from combustibles correct ? |
Don't forget to install the 3/4" plug in the TPR valve to make it a real rocket
But how would you know which model or year the WH is if its painted? Marcel Gratton, NACHI04011210, CMI, NHI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
True but the one inch clearance (thanks thought it was one) is certainly violated by flammable paint on the casing is it not ?
| Word count of our inspection narratives as of today tops 300,000 words. Wow. | gromicko | Miscellaneous Discussion for Inspectors | 47 | 12/21/12 8:09 PM |
| Draining a mobile home hot water heater. | Steve Evets | Plumbing Inspections | 11 | 2/20/07 11:28 PM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
