Looking to confirm my suspicions. Does this look to be a passive Radon system? There was no fan in the attic? The larger pipe is 4" PVC routed through the attic and exiting the roof. The cover to the sump pump and pipe exiting appears to be sealed. But if you look close there is a gap between the cover and concrete floor. I can't think of any other reason to have the sump vented.
John Scaparo Innovative Home Inspection, LLC Canton, Michigan 48187 734.664.5853 john@InnovativeHomeInspection.com Michigan Licensed Residential Builder 2101201845 InterNACHI MI #09041012, AHIT Member Plymouth Michigan Home Inspector
Canton Michigan Home Inspector "Helping To Secure Your Home Investment" Looking for link exchange partners. If interested send me your link. |
| Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Where does the pipe terminate??
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
Are there any plumbing fixtures in the basement? What is the height of the building drain to the exterior.....does it exit the house above the basement floor level? Last edited by Brian A. MacNeish; 1/23/11 at 2:24 PM.. |
The small pipe with check valve is the sump discharge pipe that exits the side of the home. The larger pipe run up through the subfloor next to the out side wall and up through the attic and exhaust above the roof like stack vent. There are no plumbing fixtures in the basement or other waste pipes connected to it.
The home is a two story colonial. The bathrooms and kitchen are on the opposite side of the of the home. John Scaparo Innovative Home Inspection, LLC Canton, Michigan 48187 734.664.5853 john@InnovativeHomeInspection.com Michigan Licensed Residential Builder 2101201845 InterNACHI MI #09041012, AHIT Member Plymouth Michigan Home Inspector
I agree with Brian. This is a sewage lift pump, this can be confirmed by flushing the lowest toilet 3 times and listening to the impeller kick in to remove waste if it does not then maybe it is a control for Radon that looks like a sewage lift basin.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Looks like a conventional sump pit with the addition of a sealed cover and rough-in for a Radon mitigation fan if needed.
These are becoming more common around my area. If a Radon test shows elevated Radon a fan and manometer gets added. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Still needs to be sealed tight . And if it is for radon it should be identified
Michael, I agree with you. The home is hooked up to public sewer. In this area iMichigan there is plenty of Radon. The home was built in 2003 so it may be a system prep for radon or a system intended for removal. I will suggest testing
Sump basin if I am not mistaken.
This could be below the french drain and the system being enclosed needs to circulate the flow of water because it gets large amounts of water . Per gallon an hour rate. If I am not mistaken , if it was a radon escape duct it would have an electric fan and be running 24 / 7. 1: Is the basement below the water line . Lake , high water table near the surface grading ? 2: is there a washer dryer above the unit and with in 20 feet of the basin? 3 is there a new toilet install within that area? I have seen a lot of bad ideas. I have seen and repaired may cooked up drainage systems. |
| Washington State Inspectors - Your Deadline Is Near | Mike O'Handley | Legislation, Licensing & Legal Issues for Inspectors | 54 | 4/14/10 9:15 PM |
| radon system loud | Unregistered | AskNACHI.org Inspection Questions Forum | 2 | 11/18/09 7:48 PM |
| Radon Testing Kansas City | dmoriconi | Ancillary Inspection Services & Additional Topics | 1 | 1/11/09 3:11 PM |
| Final review of Newman's radon references! | Caoimhín P. Connell | Ancillary Inspection Services & Additional Topics | 12 | 10/4/08 12:23 PM |
| Passive and Active Radon test results | rwiley | Ancillary Inspection Services & Additional Topics | 8 | 7/24/08 9:53 PM |
