What kind of connection is this, and does anyone have documentation. I was told it was the repair connections to help eliminate the issue, but just wanted to verify.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Anything stamped on the fitting Sean?
Unless the connection replaces the ENTIRE PB SYSTEM, the issue (PB Pipe) remains....
http://www.polybutylene.com/poly.html Last edited by bkelly2; 5/19/10 at 10:28 PM.. |
[QUOTE][Anything stamped on the fitting Sean? /QUOTE]
No, i did not take the time to look at them for markings. I have seen very little pb, and this is a first for the fittings of this style. The other has always been cut and dry, but i am not sure about these Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
[QUOTE=sfogarty;656040]
I did, I still want to see if anyone has the info.
I am with Brian, call it out...
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
wnapier is a non-member guest and is in no way affiliated with InterNACHI or its members.
Sean, to answer your original question - Those look like garden variety "compression fittings" to me, there is probably a ferrule inside those nuts...
Al in TN |
Because of pressure put upon the board by the Realtors Board our wording has changed, the North Carolina Home Inspection Board recommended the following language:
Polybutylene plumbing supply lines (PB) are installed in this house. PB was used as water distribution piping in many homes built from the mid 1980’s until the mid 1990’s. The piping and associated fittings have had a failure rate and subsequent leakage sufficient to have been the subject of several nationwide class action lawsuits. Copper and brass fittings used in later years seem to have reduced the failure rate, but the piping may still fail due to problems with poor installation, improper handling, or chemical reaction with the water supply. The piping in this house has (circle which apply) Brass/Copper – Plastic - fittings. The class action suits have expired and there is no longer any monetary relief for homeowners that experience a polybutylene piping failure. For more information visit: http://www.pbpipe.com . You may wish to have the plumbing system evaluated by a licensed plumbing contractor. |
[QUOTE=bkelly2;656049]Brian, I am confused when you say it is a "defect". I see poly in my area on a weekly basis, I explain it to my clients and then move on. A non leaking plumbing system is not a "defect"
Inspecting Norfolk and Hampton Roads www.procraftinspections.com Energy Audits in Norfolk www.procraftgreen.com |
Sounds better than the last version.... Did the realtors really want it to be stronger? I think the last version was for the realtors and this one was updated since the old contained bad information and had missing facts. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
[QUOTE=bbrinke;656805]
A non-leaking PB plumbing system is a defect due to the affect it has on the property value and the lack of sound, reliable utility that a normal buyer would expect from their plumbing system. Defect: 1 a : an imperfection that impairs worth or utility B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
People need to be informed. WIth that situation, I just sent the buyer some web links. They can make the informed decision. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
I believe if you read what I wrote...."I explain it to my clients" just as I would a 60 year old galvanized water pipe. Poly is prevalent in my area, I see it daily. I do not freak out about it and call it as a defect. Show me a water supply system that does not leak.
| Cross Connection Question | tmcinvale | General Inspection Discussion | 0 | 11/7/09 11:24 AM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Plumbing vent Routing Question | kweiss | Plumbing Inspections | 7 | 11/1/06 9:57 PM |
